Inertia To Pre Engaged
4 replies to this topic
#1 beanboy450
beanboy450
  • 52 posts
Posted 19 December 2013 - 01:43 PM
Basicly trying to wire up my pre engaged starter motor (originally I had an inertia type) I've been looking on here for a way to wire it up but couldn't find anything. Do you just move the big wire (that goes between starter and solenoid) over to the battery post on the solenoid then the post you just took that wire off put another wire between that and the big terminal on the pre engaged?
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 19 December 2013 - 02:32 PM
you need to get a Pre Engaged flywheel aswell..
Edited by cal844, 19 December 2013 - 02:51 PM.
#3 beanboy450
beanboy450
  • 52 posts
Posted 19 December 2013 - 04:03 PM
I know I'm on about the wiring side of thing is that the right way to wire it up
#4 Ethel
  • 26,580 posts
Posted 19 December 2013 - 04:13 PM
Simplest is to leave the inertia solenoid in place & use it as a relay for the pre-engaged one:
Put the thick starter cable onto the same post as the battery cable. Connect the other end to the screw post on the pre-engaged. Run a new wire from, the now empty, inertia solenoid post to the activating spade terminal on the new starter motor.
Which, I think, is what you said!
#5 beanboy450
beanboy450
  • 52 posts
Posted 19 December 2013 - 06:36 PM
