It depends on the extent of the corrosion obviously but if you have to remove so much material in cleaning or there is so much pitting that the seal between piston and suction chamber is leaky they will be no use. Especially in twins where the piston drop times have to be fairly similar across the pair. A new piston and suction chamber is very expensive and would make it cost more than getting a better pair to start with.
When you assemble them make sure you are using Mini Cooper spec parts rather than Midget or similar so that everything is at the right angle when installed. Check they aren't Midget carbs to start with as if they are you will have to swap a few parts that will not be included in a normal overhaul kit.
hi dan... with regards to midget carbs to cooper spec carbs.....other than the float angle what other differences are there? im only asking as im interested
cheers james
