Hi my speedo isn't reading right
I m about 15/20km slower
What should I do ???
What parts should I replace
And how hard is it to get to it ?
Thank you
Speedo Not Reading Right
felixy69
, Jan 06 2014 05:14 PM
1 reply to this topic
Posted 06 January 2014 - 05:14 PM
Posted 06 January 2014 - 05:18 PM
You speedo drive in the gearbox is the incorrect ratio. Use the guessworks page http://www.guess-wor.../Tech/ratio.htm to obtain the correct ratio. Then it's a case of buying the right one and fitting it. It should be a simple job, however is made difficult due to access. I would budget at least an hour.
Edit: Not sure if you will have to change both parts of the speedo drive - if so it's a bit of a longer job.
Edited by Stiggytoo, 06 January 2014 - 05:19 PM.
