Have been rebuilding my 1128 gearbox today.
It has new bearings and also new genuine rover baulks.
The layshaft spins freely, the main shaft spins freely, but when you put the two together, the gearbox seems to be a little tight when you turn the input gear anti-clock wise (direction it would normally turn). If you turn it clockwise it spins freely. It also seems to spin freely for the first few degrees of anticlock wise before the baulks stop to turn.
If I push the 3rd baulk ring clockwise against the slot in the selector hub and turn the input gear anti it seems free. The stand off height on the 3rd baulk was 55 thou.
Am I correct in thinking I have done something wrong with the 3rd baulk ring? The only thing I have not done yet is torque up the input gear nut, although it is nipped up, only because it is not the correct input gear for my application.
Thanks Dave
Edited by dgear1984, 07 January 2014 - 06:24 PM.
