Full Floor Pan Replacement
rust repair
6 replies to this topic
#1 danny79
danny79
  • Just Joined
  • 111 posts
Posted 11 January 2014 - 01:36 PM
hi all
i'm in the process of restoring a 79 mini.
Instead of patching the floor in various areas i've decided to buy a full pan and replace the whole along with the heelboard..
my question is regarding the removal of the inner sill/floor section between the companion bin and the quarter panel.
is there a way to remove this area with out removing the companion bin or cutting the quarter panel bottom.
i've about 50% of the spot welds removed and before i go any further with the cutting, I said i'd ask instead of making work for myself.
any advice would be grateful
thanks in advance
danny
#2 kezzkitkat
kezzkitkat
  • 714 posts
Posted 11 January 2014 - 05:16 PM
Hope you have braced it as it will cause you no end of trouble anyway its easyer to remove the bin then plug weld it back on
Edited by kezzkitkat, 11 January 2014 - 05:19 PM.
#3 Minidarren83
Minidarren83
  • 1,207 posts
Posted 11 January 2014 - 05:43 PM
hi all
thanks in advance
danny
Cut out as my hastily can and then just grind off the remaining bit that connects the floor and companion bin
#4 danny79
danny79
  • Just Joined
  • 111 posts
Posted 11 January 2014 - 06:41 PM
bracing isn't a problem, i used pull beetle bodies off there pans so know all about bracing.
i was hoping to retain the inner still stiffener as they are good in car but it appears it might be just easier to cut them out still attached to floor.
#5 Minidarren83
Minidarren83
  • 1,207 posts
Posted 12 January 2014 - 03:57 AM
The inner sill stiffener is area he's to the sill by spot welds and also to the rear heal board if it's all coming out try remove it after but you may find if your floor is In a state to warrant full replacement they will be crusty in some way. They are a simple panel to make even if you have little or no fab skills and why out old stuff back on the nice new floor
Hope that helps
#6 lawrie124
lawrie124
  • 1,709 posts
Posted 12 January 2014 - 05:53 AM
I agree with minispares. Best to get some fresh metal in there.
#7 danny79
danny79
  • Just Joined
  • 111 posts
Posted 12 January 2014 - 02:18 PM
thanks for all the advice..
think you right will just fab up new one and weld on to new floor
Also tagged with one or more of these keywords: rust repair
