How much is it approximately to have a full respray and is it a good idea to get a proper
pro sprayer to do the job?
Can you just do the outside if you want as well or is it advisable to do the inside while
shes completely stripped out?
Jimmy
Painting amie
silverdalian
, May 31 2006 10:17 PM
1 reply to this topic
Posted 31 May 2006 - 10:17 PM
Posted 01 June 2006 - 12:33 AM
How long is a piece of string?
There are varying degrees of "how much". It all depends on whos doing it, are they busy, what colour, does it need prepping, etc etc etc. Have a search through the forum to get an idea of the kind of quotes that they've been given and what a couple of our paintshop chums would "normally" charge.
After that, the only real way to find out is to call some local shops. If you can though, get some reccomendations for your area, or at least go down there and see what they are like and the finish on the cars they are doing. Paintjobs can range from show quality at good prices to "could-have-done-it-with-a-spray-can" at extortionate prices.
