Blue Saloon Mini Mini Project
Posted 08 February 2014 - 10:51 PM
Started with a wanted ad on here for a small project, had a few responses ranging from a total rebuild to needs nothing. Looked at a few that might fit the bill but all needed more than I wanted to give. Ended up spending more than I wanted but less than the seller wanted too. This is the car as advertised....
Needless to say the photo is very flattering and in the flesh the car looked very tired and displayed quite a few faults. So that made it ideal for my needs.
2 days later it looked like this
Here's a list of the issues I've found so far.......
All 4 tyres are very low, one probably illegal
Alloys are a bit tarnished
Once radius arm has loads of play - how it got through an MOT I've no idea
Rear near side brake cylinder is leaking
Exhaust blows from mid section and rubs on rear valance
Interior under carpet is wet, there's a 30mm split in the floor letting water in - again amazed it passed an MoT just a couple of months ago
Seat sliders mechanisms are both seized
Heater control cable cut so not working
Crankcase breather system open to atmosphere - another mot issue (not sure about this one)
Handbrake rubbish
Door cards damp and rotted
It's stupidly noisy
The speedo reads about 10mph out
There are holes in the dash where air vents should be
And here a some of the plus points....
The engine and gearbox are very strong
The seats are surprisingly comfortable and in near perfect condition
The body and chrome both polish up nicely
The body and subframes are very strong and contain no rot
I've got a budget of about £500 to get this to a state where I'm happy and it's good enough to take on runs and then to the odd show. My plans in order are....
Sort out the cracked floor
Get some decent tyres (maybe new wheels tyres and sell on the old to offset the cost)
Sort out the dodgy brakes
Fix the seats and fit some soundproofing
Then I can drive it for a bit and sort out the other bits and bobs at my leisure.
If there's any interest I'll bung a few photos and add a bit of a write up as I go along
Posted 08 February 2014 - 11:15 PM
Posted 09 February 2014 - 10:22 PM
Welded up the cracked floor and slapped a bit of undersell on for the time being. Put some sound deadening on the floor and refitted the cleaned carpet
Refitted the exhaust correctly so that it doesn't bang on the subframe or leak
Going to spend the week applying underseal and the rest of the interior so I can turn it around next weekend and sort out the dodgy near side brake cylinder.
Not a lot to show for 6 hours work really!, but that's what playing with cars is all about
Posted 10 February 2014 - 06:41 PM
With or without centre caps?
I'm thinking without!
Posted 10 February 2014 - 11:54 PM
New wheels and tyres today. Trial fitted
i am amazed that you have already changed the wheels on this car. thanks for not putting 13's on it! lol Also, having stuff on the roof, nice way to scratch the roof! i would take them off dude!
i hope you look after this car....i have seen it for 4 years and know it quite well.
the exhaust, its quite noisy yes, but you won't find another mini with the exact same sound. sound proof the inside but leave the exhaust dude! its a sweet sound
Posted 11 February 2014 - 07:09 AM
There's a nice car in here as you say but it'll take a couple of months to fish it out which is exactly what I want.
Ps the paint is as flat as a flat thing and will get a thorough mopping as part of the 'refresh'
Ps don't forget to ask for the photos, thanks
Posted 12 February 2014 - 07:10 AM
Can you tell which side is mopped?, left or right?
Posted 13 February 2014 - 09:04 PM
Now need two rear radius arms. That's £100 not bargained for!
Bbbbbbbbrrrrrrrrrrrrrrr
Posted 15 February 2014 - 07:36 AM
More and more convinced it's a dodgy mot. Starting to wonder about the photos? No sign so is that a sign of something bad??
Oh well buyer beware, at least when it leaves me I know it'll be right and the journey will be documented here
Think I'll post a pick of the removed brake shoes
Posted 16 February 2014 - 10:34 AM
Closer
Goes to show folks that no matter what a seller says get someone competent to check out safety related issues. Even an MOT is no guarantee of a safe car.
Thought I'd a picky of where the magic happens too
Posted 18 February 2014 - 10:05 PM
There's no brakes! Either I've bled them wrong or the master cylinder has gone kaput! Good news is I've fixed the blown bulb in the ignition warning light!
Posted 20 February 2014 - 09:41 PM
A new flexi pipe and some vigorous pedal pumping got all the goo and old fluid out of the brake lines and restored all four brakes to full working order.
Decided to have a break (pun intended) for a couple of days before tackling some of the interior issues.
Not sure if anyone is reading or interested in this lot but I'll keep going anyway.
Posted 20 February 2014 - 09:55 PM
Posted 21 February 2014 - 05:03 AM
Posted 21 February 2014 - 08:12 AM
It this case it's buyer beware. I started this in full knowledge of many of the faults. Their extent became apparent on examination and I've posted some pics to illustrate.
If some unsuspecting buyer had bought this on face value it would have no rear brakes , not enough tyre tread, and variable rear suspension geometry. The speedo would be inaccurate and the exhaust leaking.
It's also not a moan or a complaint against the seller or mot station. Perhaps I'll stop referring to the mot in future posts - we'll see what turns up next
Cheers🚙
