Lpg Conversion Mini
13 replies to this topic
#1 webby0121
webby0121
  • 117 posts
Posted 26 February 2014 - 02:02 PM
Hi, i posted a topic on this ages ago which i have been reading through.
I have decided to weigh up an LPG project and i was wondering a few things.....
What parts i would require for a 998cc stock single carb mini.
How much the parts will cost.
And has anyone done this to an A series engine before?
im also gunna put the tank where the spare wheel is.
#2 kappa
kappa
  • 1,301 posts
Posted 26 February 2014 - 02:08 PM
This is a interesting thread as I have also been looking into this
#3 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 26 February 2014 - 02:42 PM
I've looked into this too - the major issue that I can see is you need to either have the kit professionally installed or get it approved by an installer.
Some of the components (the tank as an example) are date stamped and are only considered 'safe' for a number of years - this means that you cannot just go and buy a secondhand kit off eBay and install it.
The main differences between the kits is in the way the gas is controlled, and it's the more complex controller that cost more.
I'd do some calcs and work out if it's worth doing ....from the tekki viewpoint it's probably a great talking point but from a return on investment view it may not add up.
Last thing to consider is that they need some regular maintenance, I've had a mate with a Range Rover blow the plugs out of the head and a mate with a focus have loads of issues ... both I suspect caused by a lack of correct servicing.
Cost is from about £700 fully installed, secondhand full kits on fleebay go for £50 to £200 ish
Edited by DomCr250, 26 February 2014 - 02:44 PM.
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 26 February 2014 - 02:53 PM
So why are you considering an LPG conversion in a classic mini? The classic mini's not known for being paticularly suited to long journeys and in general you need to do a fairly high mileage to make an LPG conversion pay for itself in fuel cost savings. I looked into getting one for my Clio once, and as I remember it was going to take me about two years of doing my 100 mile a day tound trip commute to get my money back. I'd imagine another issue is locating the extra fuel tank needed for the LPG. It's fairly standard to fit a wheel sized tank in the boot in place of the spare wheel, but I wouldn't imagine that a 10"/12" wheel sized tank would hold very much.
#5 vx220
vx220
  • 419 posts
Posted 26 February 2014 - 08:12 PM
You'll also be carrying an extra 40kg around with you, and remember to account for a reduced mpg when working out your figures
#6 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 26 February 2014 - 08:22 PM
Is it even possible to run multi fuel on a carb or are you planning on going completely LPG?
#7 Mpi Mark
Mpi Mark
  • 126 posts
Posted 26 February 2014 - 10:33 PM
I work in the motor trade and I wouldn't touch any car that has been lpg converted. It destroys cars resale values particularly on newer cars so it's just a false economy in my opinion.... unless it's a £500 landrover. If the car doesn't owe you much it might be worth doing but a decent conversion is expensive and you'll loose the boot. To recoup the cost of the conversion you will have to do a lot of mileage, plus the vehicle may be difficult to sell on.
Don't do it :-)
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 26 February 2014 - 11:38 PM
I'd do it on a V8 4x4 or something but not a mini! Also, does it not reduce performance?
Lpg has kind of died a death due to improvements in diesel engines hasn't it?
#9 grumpy dad
grumpy dad
  • 305 posts
Posted 27 February 2014 - 01:27 AM
Hi
yes I have done this to a 1275 A series
in austin A35
single carb HIF 44
its easy if you want to go low tec
its called open loop you fit a vaporiser in the front
hook this up to a adaptor plate fits between the carb and manifold
or between the carb and air filter
the pipe between the tank and the vaporiser is now plastic
I had to fit copper rules change
we use to get about 50 mpg at petrol prices
if you want some fun you can mix your own gas
90% propane 10% nitros but don't tell anybody
and it still ran petrol
this firm is very good
http://www.tinleytec...log/SPOLIS.html
or good old Ebay
the tank must be under 10 years old
#10 albo
albo
  • 204 posts
Posted 27 February 2014 - 12:33 PM
can`t a calor bottle be used,,and just swop over when empty as they do on fork lifts,  ;D
#11 grumpy dad
grumpy dad
  • 305 posts
Posted 27 February 2014 - 06:44 PM
Hi
yes a calor bottle can be used
but then you have not payed the Tax on it
also it would have to be one from a forklift
you move liquid from the tank
to the front of the car
#12 bpirie1000
bpirie1000
  • Area Managers
  • 2,369 posts
  • Local Club: Amoc
Posted 27 February 2014 - 08:28 PM
I find it strange that your looking at this.....
Mini is cheap to run.. Try a 4.6 range rover.....THURSTY?........
#13 DomCr250
DomCr250
  • 667 posts
Posted 28 February 2014 - 09:21 AM
Hi
It's cheaper to buy LPG from the pump than to pay for it in a bottle, but you are correct the bottle gas does not have duty on it.
Cheapest of all is a domestic / commercial LPG gas fill, but you need a pump to fill the tank fully and it's illegal to use on the road.  All the Johnathan Palmer driving experience cars used to run on commercial LPG to reduce the costs ...it's funny to see a gokart or a full race car with a gas tank in it, but it seemed to work for them.
Nice suggestion with a whiff of Nitrous in it ...now I like that - have you looked on Burgermans DIY Nitrous pages (www.nitrous.info) ...worth a look if your into playing with the stuff - he is very clever bloke.
Edited by DomCr250, 28 February 2014 - 09:24 AM.
#14 grumpy dad
grumpy dad
  • 305 posts
Posted 28 February 2014 - 11:20 PM
Hi
I have done it but only 10% buy weight
just two things to  remember
you are shifting liquid about
and every thing works at about 200psi
so the pressure is not that high
