Mayfair 998 Gt17 Turbo
43 replies to this topic
#31 MiniMenzies
MiniMenzies
  • 190 posts
Posted 25 May 2014 - 12:24 PM
All i need is the cam so it can be put back together. so then it releases other stuff like finishing the mani but putting the engine in to check clearance. I should have roughly like 15mm space once i move the actuator. plus things like intercooler. this is what the manifold is looking like now
10368839_10203156404164024_2146074280776
 EDIT
Edited by MiniMenzies, 25 May 2014 - 01:15 PM.
#32 Waltermini
Waltermini
  • 36 posts
  • Local Club: Na
Posted 26 May 2014 - 04:25 AM
Hi where did you boy the manifold parts from? Can't find them online.
#33 MiniMenzies
MiniMenzies
  • 190 posts
Posted 26 May 2014 - 11:03 PM
on ebay dude the pipes that is. others you'll have to get cnc'd
#34 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 29 May 2014 - 06:34 PM
Any updates
#35 MiniMenzies
MiniMenzies
  • 190 posts
Posted 29 May 2014 - 08:18 PM
Block has been pocketed and crank and fly been balanced. Bought another oil feed as the last one was wrong. Buying some rose joints to make some engine steadies. Nothing in the way of pictures to be honest. Im ready to start putting the engine together in a couple weeks when I'm back home. Still looking for a cam. Once I've got that it can be fully put together. list so far of parts.
Plenum
mani
fuel reg
block
head
thrusts
engine mounts
new water pump
Special plugs
Parts still to get just need to order (stuff of the shelf):
oil pump
cam followers
double valve springs
Vernier duplex
Intercooler
boost gauge
boost bleeder
piping
Fuel pump
Tacho
oil temp gauge
indicator wiring
Stuff to look for:
Cam (mg metro, 266 or a sw5)
Hif 44 turbo carb or non to convert
GT1752 mounting plate for mani
Things to make:
Exhaust
engine steadies
Catch tank or just breathers
Oil return for turbo
To weld:
Rear seat
rest of mani
rocker cover
possibly an arch
#36 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 30 May 2014 - 02:52 AM
Looks like Alfa Laval "dairy tube" - to be honest I think it's a bit thin to have a turbo hanging off it.
#37 MiniMenzies
MiniMenzies
  • 190 posts
Posted 30 May 2014 - 07:26 PM
its not dairy tube, full stainless 316L exhaust grade. 3-4mm thick plenty thick enough
Edited by MiniMenzies, 30 May 2014 - 07:44 PM.
#38 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 03 June 2014 - 03:41 AM
If it's the same stuff as shown in your photo with a vernier next to it, either it ain't 3mm thick or you've been sold a dodgy vernier. :-)
Either way - up to you, I think you may find that sags/cracks after a while unless you brace the turbo up somehow.
http://www.spdexhaus...2-23_Tubing.pdf
http://www.eng-tips.....cfm?qid=177536
http://honda-tech.co...d.php?t=2959578
As the man said in the last post - a bit of schedule 40 might be better - it' will give you about 3.9mm wall thickness :-)
Edited by Captain Mainwaring, 03 June 2014 - 03:58 AM.
#39 MiniMenzies
MiniMenzies
  • 190 posts
Posted 03 June 2014 - 03:24 PM
its what has been suggested by many people and others on the turbo mini forum who have lots of experience. The down pipe is a saab item, serving its exact purpose. I know there are many higher quality stainless materials but they are up for the job, and are also the right dimensions and perfect bends so perfect for me
#40 oliver122
oliver122
  • 1,007 posts
Posted 04 June 2014 - 07:29 PM
1978678_10202560851915590_487784679_n.jp
hi mate would you be able tell me where you got the stainless pipe from , cheers mate
#41 MiniMenzies
MiniMenzies
  • 190 posts
Posted 05 June 2014 - 12:16 AM
its 3 pieces. search for M I J exhausts. I think its from them. But if not just look for 38mm stainless 90 degree and t-piece. loads of them about. Get a decent size wall like 3 mm or more.
#42 MiniMenzies
MiniMenzies
  • 190 posts
Posted 31 July 2014 - 10:06 AM
its been a while a slight change in plan still going turbo but at a later date. Going n/a to run it in as its had loads of new internals etc. All electrics are done got my hazards working for the first time in 2 years, which is a plus. Ive just been going round tiding up the car and all the electrics. Just finishing up all the stuff i need to do before MOT. Of course when the engine is in ill post some pictures up later. Don't worry hasn't stopped yet
#43 Anthony30
Anthony30
  • 1,466 posts
  • Local Club: N/A
Posted 03 November 2017 - 10:51 PM
:tumble:
#44 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 04 November 2017 - 10:06 AM
Here is the last post on turbomini
http://www.turbomini...p=vt&tid=599448
