Italian Job Rebuild
#106
Posted 01 November 2018 - 06:20 AM
#107
Posted 01 November 2018 - 11:23 AM
It's looks good though keep it up
YetI
#108
Posted 01 November 2018 - 08:55 PM
I have seen them but there not cheap . Going to get the car on the road and see if I have any problems if I do I'll think about one .Have you thought about a DSN classic engine steady,
YetI
#109
Posted 08 November 2018 - 09:39 PM
Hopefully have the car running in the not to distant future .
#110
Posted 10 November 2018 - 08:43 PM
#111
Posted 11 November 2018 - 01:31 PM
Poss my favourite build thread - I’ll be using yours to help mine and for inspiration
Thanks very much !
#112
Posted 11 December 2018 - 09:55 PM
For the time being a couple of before and after photos.
#113
Posted 12 February 2019 - 09:35 PM
#114
Posted 13 February 2019 - 09:39 PM
I'd got an old mg metro inlet in my spares pile so I decided to dummy it up . It sat the carb at better hight and I could get the air box to fit. I did have to trim the stud that comes out of the carb air intake to let the filter box pass but it's a good fit now.
An issue I had with the mg manifold was that the flanges were a different thickness to the lcb manifold in fitting. I had to spend a couple of evenings carefully filing the flanges . I'm pleased with the result !
#115
Posted 13 February 2019 - 09:46 PM
looking good - it's all the little final details that take the time but are worth the effort.
#116
Posted 13 February 2019 - 10:28 PM
I got all the starter motor connected and the rest of the wiring and I decided to crank the engine over to get some oil pressure . I cranked and cranked the engine over but couldn't get any oil pressure. I was just thinking how I was going to re prime the oil pump and I thought I'll give it one more try and the oil light went straight out . So I was more or less ready to start the engine. Very tempted to give it a go but I thought I'm going to bleed the brakes first and get them working as soon as the car is running I'll want to try and drive it.
So I'd all the engine bay together and filled the radiator with coolant and I thought I give my dad a call to come down and have a go at starting the mini first time . Thought it was only fair as he had rebuilt me the engine !
We filled the carb with petrol and turned the engine over and absolutely nothing happened. We removed the plugs and there was no spark. I removed the coil and distributor and tested them out as per the haynes manual.
Both the coil and distributor test out to be faulty. I'm unsure what caused this weather one parts failed and took the other with it. I looked at buying the parts to repair the distributor and a new coil but the notice and ebay you could buy a powerspark kit with a brand new distributor,coil and leads for not a lot more money the parts I needed to repair my distributor.
So this weekend's job is fitting it and seeing if the engine runs !
Obviously the red plug leads are an instant 100 bhp boost lol !
Edited by Gillybobs, 13 February 2019 - 10:32 PM.
#117
Posted 17 February 2019 - 09:10 PM
We have a runner ! Got to sort out the new distributor now see if can be replaced. Very happy to finally have the car running !
#118
Posted 17 February 2019 - 09:15 PM
a little video here .
https://www.instagra...d=11dyps3j2ijup
#119
Posted 23 February 2019 - 08:53 PM
#120
Posted 24 February 2019 - 10:11 PM
on a brighter note I've just got new set of nankang tyres and I'm sending the wheels for refurb so the car wiLl be another step forward.
