1987 City E
#31
Posted 21 March 2014 - 05:34 PM
#32
Posted 21 March 2014 - 06:47 PM
#33
Posted 21 March 2014 - 07:05 PM
#34
Posted 23 March 2014 - 10:45 PM
So much for a week of work, can't get there because of this, I wonder if the cows miss me?
#35
Posted 24 March 2014 - 04:05 PM
#37
Posted 24 March 2014 - 06:47 PM
#38
Posted 24 March 2014 - 06:50 PM
#39
Posted 24 March 2014 - 07:50 PM
If you're interested this is the one I bought - http://www.machinema...c-impact-wrench
Thanks, the problem with that is would I have to buy a new socket, or could I use the normal socket and not an impact socket?
#41
Posted 24 March 2014 - 09:37 PM
Providing that the drivers side doesn't have a wider drum or spacer installed it could be the rear subframe. Seems fairly common on aftermarket replacement subframes for misalignment when installed.
#42
Posted 24 March 2014 - 10:18 PM
That impact wrench is great, I've got the same one! Loadsa power. Would be best to buy a impact socket as you wouldn't want a normal socket shattering and bits of socket flying everywhere :)
#43
Posted 24 March 2014 - 10:21 PM
The only problem is the only one the correct size cost £20
#44
Posted 24 March 2014 - 10:22 PM
Is there any way to remedy it? Sledge hammer? :)Providing that the drivers side doesn't have a wider drum or spacer installed it could be the rear subframe. Seems fairly common on aftermarket replacement subframes for misalignment when installed.
#45
Posted 25 March 2014 - 12:10 AM
You're probably better off taking some measurements to start with to find out if it is the subframe which is out. I'm not an expert on this but I would suggest that a sledge hammer isn't a good idea.
