1.0 Ecoboost Mini
16 replies to this topic
#1 Sefud
Sefud
    Starting My Mini Up
  • 2 posts
Posted 29 March 2014 - 10:35 AM
Hi guys just wondering if anyone has planned or attempted a ford 1.0 EcoBoost conversion. With the engine being around for a while they're popping up on eBay reasonably cheap so the thought of this little 3 cylinder boosted engine quite temps me..
Wonder if anyone could help me out here, couple of queries.
Would the best way to go about this be to buy a bare conversion frame like that used in Vtec etc builds and then weld up the required mountings yourself?
Would the 5 speed box fit?
What other issues may you encounter? Cheers for the help guys sorry for being a bit of a noob. I'm new.  :shy:
#2 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 29 March 2014 - 10:56 AM
You'd have a few issues with the fly by wire throttle and other associated electronics with that engine. Probably better to run  a standalone ECU with it, and fit a throttle cable.
I think a few people have fitted daihatsu charade engines I think, which are a similar concept.
#3 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 29 March 2014 - 11:37 AM
I'd love to see this done, I've been in a mates Fiesta and the 1.0 turbo lump really works well in a small car.
#4 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 29 March 2014 - 11:48 AM
Was very interested in doing this a while ago but they were too expensive at the time, if i remember rightly, the 5 and 6 speed boxes are the same size but the 6 speed gets the ratios a bit better for mini wheels
i will probably attempt it over the next year or two after i have my engines built and i have a bit more cash about me but i reckon it would be a cracker conversion
Adam
#5 Sefud
Sefud
    Starting My Mini Up
  • 2 posts
Posted 29 March 2014 - 01:58 PM
thanks for the replies guys, its more and more tempting the more i think about it. The Engine itself is supposed to be brilliant and like you said they were a tad expensive but seem to popping up now and then for a reasonable price.
#6 mini-geek
mini-geek
  • 1,169 posts
Posted 29 March 2014 - 02:06 PM
Someone has already touched on this but you need to makesure you can get it running without the car.. Just buying an engine will be no good, on many modern cars you need the car to swap all the electrical items over..
For instance corsa VXR, Ive seen an unfinished project where he had to use the corsa's clocks or the engine wouldn't work with the original ECU
It's not impossible, but you will need more than an engine..
Other than that if it fits in this hole it fits!
#7 l_jonez
l_jonez
  • 1,453 posts
Posted 29 March 2014 - 03:53 PM
This is one on my lists of future projects, someone will probably get there before me.
I'd be buying a whole (scrapped) car as you would need the ecu loom etc
#8 bartman
bartman
  • 265 posts
Posted 29 March 2014 - 04:18 PM
any thing is possible but you would be better off buying a complete car. probably pop up often and cheap as an insurance write off then you will have everything you need to convert it.
#9 charlieb150
charlieb150
  • 46 posts
Posted 29 October 2015 - 12:40 PM
Yes me
#10 thedjse
thedjse
  • 166 posts
Posted 29 October 2015 - 07:12 PM
Yes me
You have an eco boost mini????
Pics???
#11 petey81
petey81
  • 1,248 posts
Posted 29 October 2015 - 07:16 PM
Theres one on fb already done! I will try and find it
#12 Ethel
  • 25,379 posts
Posted 29 October 2015 - 10:26 PM
Looking forward to reading about this.
Would  the cat not also be a problem if you tried to run the original engine management? Something which has a diesel stablemate to pinch the gearing off could help.
#13 charlieb150
charlieb150
  • 46 posts
Posted 29 October 2015 - 11:19 PM
Look one the other build thread
#14 charlieb150
charlieb150
  • 46 posts
Posted 29 October 2015 - 11:20 PM
Please do if it's a clubby estate it's mine... If not I'm interested
#15 charlieb150
charlieb150
  • 46 posts
Posted 29 October 2015 - 11:26 PM
Just seen zcars state their selling one for 30000k? But have they completed it
