yeah it really takes the effort out of brushing it. The gun was only £12 (although you do need a compressor) and the shutz is 4 x 1liters for £8. I've done both wings, inner wings, the drivers side floor inside and out and both sills and have used 1.5 litreslooks very neat n tidy, you using the spray gun thingy?
under sealing
miniman5
, Jun 25 2004 08:09 PM
18 replies to this topic
#16
Posted 26 June 2004 - 04:15 PM
#17
Posted 26 June 2004 - 05:32 PM
if you are spraying over the weld thru zink spray , make sure it is overpaintable as there are several types and some are not overpaintable so anything painted over this type will just peel . the standard type of underseal is fine if you prepare the surface properly . I usualy waxoyle over the underseal when it is used underbody .
#18
Posted 26 June 2004 - 06:41 PM
Confuzzeld
#19
Posted 28 June 2004 - 06:48 PM
ace that looks ace under that arch how did u get it that good??
