Evening all,
I seem to be blowing head gaskets like its going out of fashion - fresh build 1293, sw5 cam, vmax m45 blower, omega 18cc pistons, bk450 head gaskets, new head studs, the list goes on.
Its blown 2 head gaskets and spewed coolant out of a fresh third. A compression test prior to removing the head reveals 160-165 psi across the board - I'm told I should have 150 psi tops.....What do you guys run? Should I be concerned with 165psi?
Compression ratio is unknown.
Block has been skimmed and head skimmed twice in the time I've had it.
Any thoughts?
Edited by minivanman8, 17 April 2014 - 08:23 PM.
