Volvo Drivers Clutch Cylinder Size?
Posted 17 June 2014 - 07:38 PM
I've currently got the standard .75 one supplied by z-cars. This has been bled twice unless there's a special trick I'm not aware of? But I still have full pedal travel; I have no idea if this is normal though!
I really don't want to drop the box if it can be helped so suggestions or tips appreciated before I go down that road.
Kev.
Posted 18 June 2014 - 06:52 AM
Hi Kev,
Do you have any travel in the slave cylinder on the gear box when depressing the foot pedal?
Posted 18 June 2014 - 09:39 AM
Posted 18 June 2014 - 11:55 AM
Yer give that a go as I would have thought that a 0.75 would do the job. I had to upgrade from a 0.625 to a 0.75 when I changed my carbon clutch out for the 08806 Exedy.
How does the pedal feel, is there a clutch like resistance there or does it go to the floor like you've lost your brakes?
Posted 18 June 2014 - 12:31 PM
The pedal (in my mind) feels like it should, I've got that feeling of fluid movement, but no real resistance, its very smooth right the way to the floor but not that worrying dead pedal feeling; hope that makes sense!
Posted 18 June 2014 - 06:17 PM
Did it get stored somewhere damp or not heated for a season or more? Then possible (like you say) plate stuck.
Are you running stock clutch and dual mass?
Posted 18 June 2014 - 09:37 PM
Posted 19 June 2014 - 06:37 PM
Getting to the place I need (hopefully) so time to look for a bigger master cylinder.
Posted 19 June 2014 - 08:34 PM
Glad you have got it cracked though!
Posted 19 June 2014 - 08:56 PM
Posted 24 June 2014 - 09:10 PM
Posted 25 June 2014 - 10:06 AM
Clutch all sorted. Installed a bigger cylinder tonight, bled the system and drove her for the first time; albeit 10 yards back and forth lol
Cool, how much do you think you've got to do to get her finished???
Posted 25 June 2014 - 10:56 AM
Well unfortunately I need to re-spray the front end, but that's in hand and not a big deal with regards to the work required, that aside I have the following left to do:-
Wiring:-
1) wire front and rear heated screens
2) complete sensor wiring to speedo and programme
3) wire opening rear windows
4) wire central locking motors to control unit
5) find location for washer bottle and wire
6) tidy up wiring and fix in position
Interior:-
1) modify dash to clear n/s door handle
2) fit dash and speedo
3) fit carpets
4) make centre console
5) fit seats
6) complete rear bulk head
7) fit centre console and gear linkages
8) hoover
Exterior:-
1) paint
2) fit front and rear screens
3) fit rear high level lights and central brake light
4) wheel alignment
5) wash
6) seal paint
7) MOT
There are other oddsy sodsy bits to do, but that's the bulk of the work above and being realistic the work load isn't that great and the biggest factor is the paint. The other items are quite time consuming, but nothing a few hours a night won't sort out. Its always the unknowns that cause the issues and as a few problems have cropped up I'm expecting a few more! I seem to have a clunk when I reverse and then stop, almost as if something is lose, but I will investigate this when its up in the air and give her a good old shake down. I'm wondering if this is a dodgy fitting bolt and rose joint as I've come across and changed a few of those already.
Posted 25 June 2014 - 08:21 PM
How did you get on with your tuning guy or is that on the list to do? Also who are you using for your wheel alignment / corner set up?
Glad it's on the rite track!
Posted 25 June 2014 - 09:10 PM
