Brake Pads Recommendations
No replies to this topic
#1 nennokair
nennokair
  • 11 posts
Posted 21 June 2014 - 11:14 PM
Hi
After a 5 year absence im getting my busa mini back on the road. Im sorting out a few things that were never really done propery the first time. One thing i remember was that i felt the brakes needed to be better. I have kad four pots on the fronts with vented discs and greenstuff pads. Rears are the standard sierra calipers and pads, and standard 1991 servo assisted master cylinder.
It did stop ok but i never felt too impressed. Having only had greenstuff pads on it i cant blame them as such, yet. With the car only weighing 550kg and a light front end do i need pads that operate at lower temps. I need them in the classic fast road/light track use operating window. Ive got a bias valve fitted so there is some adjustment there to get them dialed in. I dont really want to start changing master cylinder setup unless i cant improve them with a pad change.
What pads do you guys use/recommend?
cheers
Andrew
