Rubbing Arches
3 replies to this topic
#1 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 01 July 2014 - 10:12 PM
I have fitted a Hi lo kit, got the mini set up and handling as I require. The only issues is that the front wheels catch on the front wing on full cornering.
Now I understand the simple answer is to raise the ride height or cut away some of the wing. This is not what I want to do, so I was thinking that if I fitted a camber and tracking kit sold by minisport, the 1.5 degrees kit, would that bring the wheel in enough to clear the arch, or would it not make any differance?
To clarify it is catching on the front of the wing and I am running 12" 5.5 Minilights with the yokohamas on.
#2 Iamstib
Iamstib
    Just On Tickover
  • 5 posts
Posted 04 February 2015 - 01:36 AM
im having exactly the same problem. How did u go?
#3 maximas
maximas
  • 108 posts
Posted 04 February 2015 - 06:08 AM
This happened on one of my mates mini s ...you will need to cut some of your front wing off....not a lot..but a bit...
#4 nicklouse
  • 17,931 posts
Posted 04 February 2015 - 07:49 AM
Fitting neg camber arms may create other issues.
What you need to do is have your caster and camber checked.and get that right then look at removing wing and A panel as required.
