1994 Red Sprite Project
152 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 05:43 PM
Hi All,
I've been doing this mini now for about 3 years and it's still not finished. I am however making progress so I wanted to try and capture some of it.
So, as I've said it's a 1994 Red Sprite with a 1275cc engine that had done 47K when we bought it for £1,500.
I knew it needed some work but I didn't realise quite how much - but then how many of us have said that!
Here are a few photos of it to start with. I didn't take enough of it on the drive so these are shots of bits of it.
So this was June 2011. We started by taking out the seats and carpets and things didn't look too bad. We could see it had oversells fitted and there was a small patch of rust on one inner sill so that would need replacing but that was do-able and the front o/s floor panel would need some attention.
The engine was stripped down by myself and Tom, my son. At that point I realised that I don't have the skills to get the engine right so we shipped it off to ML Motorsports in Medway for a full rebuild. I am told most of the work is done on that but I put it in to mothballs while I tried to get the body in to a condition ready to take it.
We got it all stripped down, engine out, electrics off, loom out, ready to tackle any rust - and that's what I have been doing for 3 years on weekends and evenings.
I have been learning a lot with a lot of help from this forum (without it I couldn't have got this far that's for sure).
I will do a few more posts of the interim period to show some of the problems I had and then I will show you where I am as of 5th July 2014 - which is a landmark day in the life of this mini!
Cheers,
Rod
#2 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 06:01 PM
Here are a few shots of the engine during strip down. Sorry if some of them aren't too clear.
#3 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 06:23 PM
So, let show you some of the more obvious rust areas and a few more of the engine that I found. Sorry that this is just a long line of photos of rust but this is what it was.
Rod
#4 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 06:42 PM
So lets do a few repairs that I have done so far. This is the front valence plus a few patches over some of the holes for holes I showed you in an earlier post.
#5 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 07:50 PM
I wanted to try and get a list of most of the bits I've bought or things I've replaced and work I've done.
I won't include the bits in the engine as that is being done by someone else.
n/s sill -  coversill taken off, inner and outer sills replaced.
o/s sill - coversill taken off, inner and outer sills replaced.
Boot floor - fully replaced the panel right through to, and including, the rear seat.
Boot brackets to wheel arches - both sides
Rear Valence
Valence Closers - with additional supports
Both rear companion bins
Wings - new bought but not on the car yet.
Patches applied to: -
front valence,
rear floor,
o/s flitch panel - bottom around floor and where air vent is,
n/s flitch panel the same,
n/s door step - patch inserted,
windscreen corner panel closers on both sides
Rear boot section containing hinge holes
Patch to o/s rear wheel arch - both points where arch meets 'floor' and above shock absorber mount.
Patch to n/s rear wheel arch - both points where arch meets 'floor'
Patch to n/s crossmember end where the shock absorber arm sits
Added a strengthening piece right across the footwell
I bought a new rear subframe - that is stripped, etched, primed, painted in black hammerite and then covered in EastWood's Rubberised spray.
The front subframe was very good. so I stripped it and treated it like the rear BUT I painted it in yellow hammerite and then did a two tone strip for rubberised spray. - hopefully I can attach a photo of that.
Mechanical parts  - 99% of which come from MiniSpares: -
Converted from 8.4 disks to 7.5 disks - so that's new hubs, disks, balljoints
New KYB Gas Shocks. Didn't go adjustable but did go uprated for a better ride
New outer CV joints
New inner Pot joints
re-furb'ed my drive shafts
New Upper suspension Arms
New adjustable lower suspension arms
New adjustable tie bars
New steering rack
New track rod ends - went for the longer ones to give more adjustment
New top shock absorber mounts
New Cones front and rear
New Hi-Los on the front
New knuckles all round
re-furbed radius arms - used ones I had
New adjustable camber brackets on rear subframe
New (assembled) drum back plates
New drums with built in spacers
New rear hubs
new Timken bearings front and rear
New brake pipes
Servo re-furb kit
Cleaned servo brackets and rubberised them
New Master Brake Cylinder
New clutch master cylinder
New brake regulator
New Wheel studs
Dunlop D1 Alloys
About a million new nuts and bolts of various sizes.
I think that covers the main points
Rod
#6 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 08:00 PM
Up to Date
Today the mini moved on its own wheels for the first time in 3 years. Ok so I pushed it but I don't care. It's a big day for me.
You will see that I have removed the o/s A panel and had the drivers door off as it needs re-alignment. I will be looking at that over the next few days to see if there has been any movement but thanks to NordicMin from this forum for giving me a hand to get my stuck door open and diagnose the problems.
Cheers,
Rod
#7 big-jay
big-jay
  • 518 posts
Posted 05 July 2014 - 08:17 PM
Some good work going on here, bet it felt great to get it on wheels again !
#8 rodandtom
rodandtom
  • 998 posts
Posted 05 July 2014 - 10:18 PM
Thanks,
I was beginning to think I would never see it. I wouldn't be surprised to have turned around one day and found I had ground the entire car in to a pile of dust.
Rod
#9 rodandtom
rodandtom
  • 998 posts
Posted 06 July 2014 - 08:56 PM
Only managed to trim some of the doorstep out and part of the lower rear quarter panel. I also cleaned up the bottom of the driver side door and treated one little patch of surface rust.
Rod
#10 rodandtom
rodandtom
  • 998 posts
Posted 07 July 2014 - 07:53 PM
Hi,
Today I did two things mainly.
Firstly I stripped off all the furniture from the boot lid, ready to tap out a dent/ crease and prep it for painting.
Then, I cut out the sections of the lower o/s quarter panel and the rest of the doorstep.
I had bought a panel that did both the quarter panel and doorstep but i didn't realise it was a Magnum panel. It won't fit without quite a bit of playing around. I've cut along the curves of the edges so that I can make the curves match the panels that are already there - see photo. The last step on the replacement panel wasn't deep enough either so I flattened that right out and tried to introduce a new step.
In the end I split it in to two sections then cleaned all the old metal and the new edges up, etch primed them and drilled loads of holes to do plug welds.
I've got a bit more to do on the doorstep and I think I will redo some of the tacks on the quarter panel. I'm not happy with them.
Lots of tidying up to do and some filling in of areas to make it tidy.
Rod
#11 rodandtom
rodandtom
  • 998 posts
Posted 08 July 2014 - 04:50 PM
Hi,
More work on the quarter panel and door step again today.
Ground down the welds and did some tidying. In the pictures you can see that the quarter panel is now attached at the top. I need to adjust the sill and then I can plug weld that.
On the quarter panel you can see I've tidied up the plug welds I did yesterday. I think they are ready for a skim of filler and I've bought a big drum of U Pol Fantastic filler for that.
On the ends I had to make cuts along the curves to try and get the panel to fit. I've done one pass of welding and dressing back on the rear of the panel and just done some some filler welds on top - that will need dressing back tomorrow. I will need to cut along the lower curve as well and match that slope to the existing one. Lots of fills to do there but if I take is slowly I should be able to build it up. Once that's done I can then join the two panels together but only once I've joined the quarter panel to the sill. That should act as a good base.
If anyone can see a better way of doing this then do let me know. This is slow going but I think it will work.
Cheers,
Rod
#12 rodandtom
rodandtom
  • 998 posts
Posted 09 July 2014 - 07:13 PM
Today I did more on the door step. I filled in the final sections to the curves in the doorstep with welds, tidied up the welds with the grinder, etch primed them and then slapped the first load of filler in.
Incidentally, I tried U Pol Fantastic filler after reading a recommendation on here from Sonikk and I must say, what an easy filler it is to work with. It goes on so smoothly and if it sands half as well then I am going to do a bang up job.
Also, I prepped and did a first fill on a crease in the boot lid.
Once that dries and my sanding disks arrive I will attack it with the DA and then hopefully I can finish this off to a good standard.
More photos, of course.
Rod
Edited by rodandtom, 09 July 2014 - 07:14 PM.
#13 rodandtom
rodandtom
  • 998 posts
Posted 13 July 2014 - 03:56 PM
I've been rubbing down the door step and quarter panel and I've re-filled it, ready for another rub. I am also getting ready to do a trial fit of the A Panel and door to try and sort out the gaps tomorrow.
Rod
#14 rodandtom
rodandtom
  • 998 posts
Posted 14 July 2014 - 08:13 PM
Hi All,
Today I worked out what shims the driver side door needed. I then clamped in the A Panel and the front wing to see what the full door gap will be.
As you can see, the shims adjust the door gap so the lock is right, the top gap is good but the gap to the A Panel is pretty wide at the bottom.
I am considering how to close it. I could weld metal on to it or I could not fold the flap right over and then plug weld within the panel rather than along the folded over part.
Anyone got any thoughts?
Rod
#15 rodandtom
rodandtom
  • 998 posts
Posted 15 July 2014 - 06:29 PM
Hi,
Big Day for the Red Wonder!
I was (badly) fitting the off side A Panel when Alan (NordicMini) came round and showed me the proper way to get it done. Lots of advice on here says the best way to fit an A Panel using a block of wood and vice grips to fold the lip over. Alan showed me another way that works really well. Pre-fold the lip over so that you have to slide it on to the flitch panel. It grips the flitch panel and makes it easier to hold it steady while lining it up.  Once that's done you can then squeeze the lip tight around the flitch panel using grips and something to shield the A Panel, and then you can weld the lip to the flitch panel.
I had got the door lined up already so this just meant that I needed to get the gap right. Alan also spotted that the panel had been pulled in and so was catching the door edge. That was adjusted.
Next we put on the wings and bonnet to check the gaps. All told, the front of the wings, the edge to the A Panel and along the wing seat were fine. It's the gap to the scuttle that was the problem. After much clamping and thumping of the panel we reached a point that it was as good as it was going to get.
I've now welded in the A Panel, and both front wings. I do need to tidy up all the welds and I also need to tidy up where I blew a hole in the front panel but that will come out in the wash.
So, a great day I feel for Mini RodAndTom! It actually looks like a proper car again  ;D
Rod
