Dismantling Drive Shafts, Trouble Splitting From Hub End.
Posted 05 July 2014 - 06:30 PM
I am having some issues dismantling my driveshafts and I am after some information.
I am needing to remove my driveshafts from my hub whilst keeping the car mobile, from my experiences I can not just remove the hub nut and take the shaft out that way as the hub does not stay complete.
Looking at the shaft I have noticed a circlip of some kind around the splines. I can only imagine this is what needs to be removed for the shaft to come out of the hub. Despite what I have tried I just can not get this circlip off.
I've also noticed that the driveshaft has a recess, not far from the hub. Do I need to use some kind of tool which sits in the recess and pushes the hub off of the shaft?
Despite all of my efforts, and I have removed so many driveshaft circlip in the past I've lost count this one has me stumped.
My searches of the forum and google only seem to show removal of the driveshaft from the car but not how to dismantle the shaft down to bare shafts and joints.
Any help would be great, am I right in trying to remove the circlip and remove the shaft this way?
Posted 05 July 2014 - 06:40 PM
Posted 05 July 2014 - 06:50 PM
Posted 13 October 2014 - 01:26 PM
Can you buy a replacement for the thick clip at the splines? Mine is broken (actually the pot joint end) Otherwise I was thinking of a blob of weld?
I have tried 2 sources but each time have received a thinner clip (not the inner one)
Posted 15 October 2014 - 01:21 PM
You can - but they aren't a common replacement part as they are rarely removed.
I got a pair from a Morris specialist a while back by quoting the part number - the Mini is not the only car that uses them.
Iain
Posted 15 October 2014 - 01:54 PM
Then again.......
https://www.somerfor...roducts_id=2983
Out of Stock
http://www.rimmerbro...Item--i-17H8597
No Longer available
I think I'd be trying these ones
http://www.thexpart....---CIRCLIP.aspx
Seems that the Netherlands has almost the entire world supply from some quick searching.
Posted 17 October 2014 - 07:38 AM
Thanks for the info - ordered from a place in Barnstaple that came up on the xpart site.
Posted 17 October 2014 - 12:40 PM
I didn't think there was a thick clip at the pot joint end - the joint sites against a shoulder (and older ones had an o-ring seal there too)
Posted 22 October 2014 - 12:39 PM
Definitely clips - got broken when I had to cut the pot joint off as it wouldn't budge due to corrosion.
Posted 22 October 2014 - 01:42 PM
FS
Posted 26 October 2014 - 04:25 PM
Hi, can I just confirm that the thick circlip in the first photo is going in to the hub side and not the cv/pot side. I was just about to rebuild mine and have forgot which way round it went. It was some time ago
Posted 27 October 2014 - 08:01 AM
Posted 31 October 2014 - 03:29 PM
It is indeed hub end, of you look you can see a dirty red caliper
Posted 01 November 2014 - 08:14 AM
Thanks , the only thing now is the wife says it's to early, to start knocking ball joints out with my big hammer
