1) Are you running a metro radiator in your blue mini? How hard was it to fit apart from cutting out the front bar from the panel and welding in a crossbar? I take it you're not running a flip front?
2) What compression is safe in a 848, 998 for running a turbo? Whichever is chosen will probably be bored oversize (either +020 or +040), and i've heard of 848's running at around 12:1 compression (not turbo though).
3) What does one do if a turbo gearbox cannot be sourced locally? I can rebuild a regular box but if itll last a month, then I simply wont bother... Full straight cuts are not really an option right now :\
TurboPhil, some questions!
Pavel
, Jul 01 2004 04:27 PM
2 replies to this topic
Posted 01 July 2004 - 04:27 PM
Posted 01 July 2004 - 05:26 PM
I used to run the Metro Turbo radiator up front, i don't any more as i have a big intercooler up front so i've had to go back to the side mounted radiator.
To fit the Metro radiator i had to cut the crossmember as you said, i then made a new brace bar. The radiator was then mounted off brackets on the subframe, it's not to difficult really. The car is not a flipfront.
Compression ratio is governed by what boost you plan on running basically.
The Metro Turbo had a compression ratio of 9.4-1, & ran a max boost of 7psi. This is pretty much on the limit as far as detonation occuring. As a rough guide 8.5-1 should be fine for 10-12psi, 8.2-1 for 15-16 & 8-1 and below for 20+ psi.
A Turbo gearbox is just a standard A+ gearbox, the only difference being that the first motion nose bearing is slightly bigger. Otherwise there is no difference.
Hope this helps.
Phil. :grin:
Hope this helps.
Phil. :grin:
Posted 01 July 2004 - 06:04 PM
oooopsie... i think i underestimated then....
i worked out my CR to be roughly 8.2:1 give or take... and i was gonna run 4.5psi just so i dont blow stuff up. think ill have to wind it up a bit
