To all of those knowledgeable wiring wizards out there, i am in need of great assistance!!
I will hold my hand up and admit im a complete novice with wiring...
I have a zcars loom which is all nicely labelled up, it has a plug saying 'ecu plug in' but where im struggling is that the ecu doesnt have a suitable 'male' plug coming out to slot into the 'ecu plug in' connector on the zcars loom. Once ive got the looms all connected up, i then need to wire up the starter motor which has a suspicious bolt coming out of it which i can only presume is meant for a connection point to be bolted onto.
I also need to get the battery wired up into the loom.
Heeelllllp! total novice here so any help would be gratefully received and pictures would be even better.
Even if your not a wiring genius, but you have a hayabusa mini, if you could take some close up pictures of around your engine (starter motor, ecu etc) that would be equally as helpful.
all the best,
George
