After about a year of near constant illness / medical set backs I'm finally in a position to start firing on a new project.
Owning a saloon for a few years taught me that it's too small, once I include the wheelchair into the equation, for anything but smallish trips.
So new plan is get an estate and make it epic.
In lieu of this, I have to part with Ogy. I'd rather do it as a 'finished' complete car but if needs be I guess he could become a pile of parts.
So I turn to the learned ones on here for some info.
Car details:
1994 1275 Automatic Saloon.
Currently minus an engine, this is because I have no idea the approximate sale cost of with one plus MoT / Tax compared to without - it may not be cost effective to bother finding one given the relative disinterest in automatics.
Okay, so here's the fancy bits list which I'll add too as I remember more of them I'll try and do it front to back for ease of my memory.
- Solid shell, no welding needed for a long time to come any hint of the brown stuff removed with prejudice and replaced.
- Debumpered - front and back
- Tubed arches
- Rear 3 windows tinted - rear dark smoke, side windows limo black
- All "brightwork" is coated black
- Custom Grill
- Rear window louvre
- Smoked rear lights
- Cibie H180 headlights with independent, uprated, fused power coated in Lamin-X lens protectors
- New windscreen and seals front and rear
- Custom consoles dashboard with 3 gauge cluster (box of gauges included for choice) and 2 dial speedo
- Intermittent wiper system fitted
- KJB Drop bracket (Laser cut, tig welded. Not alloy)
- Mountney 12" wheel
- New carpets throughout
- New black headlining
- Carbon wrapped interior mirror
- Tex wing mirriors
- Alloy interior handles
- 6.5" components in under-dash aperiodic pods
- Drivers side rear pocket sub enclosure (18L volume) with 10" aperture
- MG ZR front seats on custom subframes
- Newton rear seats
- Rear shelf board
- Fully mass loaded front to rear with increased deadening/dampening in the cabin area to reduce road noise
- Fully adjustable geometry kit front and rear - Minispares kit.
- Gaz lowered dampers all around
- Minitastic "Fast Road" coil spring conversion with adjustable alloy trumpets
- 10" Revolutions
- All bushes, basically anything rubber and perishable is new of 1 year ago
- Refurbished rear subframe
- Uprated earth and main power lines
- Hi output battery
- I'll throw in the Stormforce cover too - won't fit an estate
Think that's about it off the top of my head, if anything else springs to mind I'll update.
If anyone has some idea what the value would be both running as an auto with tax & test and without as a ready to go conversion that would be super duper.
Here's some pics:
