Engines
billtheminiman
, Jul 01 2004 09:50 PM
12 replies to this topic
Posted 01 July 2004 - 09:50 PM
I have a mini 1000cc manual engine, with big ends gone. I have also a mini 1000 auto with break bands gone in the auto gear-box.
My question is can i strip the auto gear-box off, and use the engine for the manual with the duff ends? if you could confirm or not, whether it would be possible, i would be most gratefull. Billtheminiman :sad:
Posted 01 July 2004 - 11:45 PM
hi bill
i don't think it is possible to swap an auto engine for a manual, as I believe the block castings are different. I'm not 100% sure exactly in what way, but i've seen posts in the past saying its not possible to do it. Sorry to disappoint!
Posted 02 July 2004 - 09:37 AM
If you are going to the trouble of splitting the gearbox and block why not just replace the big ends (and everything else at the same time) it is not that difficult or expensive to do.
Posted 02 July 2004 - 05:41 PM
It isnt possible to interchange to two, they are differnt Big ends are only around £30 at the most. While you at it, you'll need to get the crank measured by your local engineers (who can suply the bearings) to find out what size you need. You might find it needs a re-grind which should cost around £20. And if you replacing the big ends you would be as well to change the mains and thrusts too. The whole job including gaskets should cost less than £100.
Posted 02 July 2004 - 06:42 PM
Cheers everyone, your probably right.
What about a manual 1000 gearbox goin on a 1275 engine.? Would the same apply.
i have also a 1275 engine with a shot gear-box, what about exchanging the gearbox from the duff engine onto the 1275.?
Posted 03 July 2004 - 06:22 AM
This is possible. If you use the 998 'box tho, you'll need to change the 3 drop gears to the 1275.
Posted 03 July 2004 - 08:32 PM
Thanks everyone, i have decided to hang fire for amo, but at least i now know what directions to take.. Hope i can be of any help for you all if you have any problems..
Thanks again Billtheminiman
Posted 04 July 2004 - 06:46 AM
just out of intrest, what are the differences between an auto engine and a manual engine?..
Posted 04 July 2004 - 07:10 AM
On a normal engine you have stick which you have to attempt to shift the gears with. Auto does it for you
Just kidding, the auto block is different, im pretty sure the gearbox mounting points are different, the subframe is also different
Posted 04 July 2004 - 07:37 AM
the crankshaft on an auto is differant to take a torque converter instead of a flywheel and the block has no dipstick hole .
Posted 04 July 2004 - 10:04 AM
And the auto engine ways about half as much again as the manual one, and they smell...
Posted 04 July 2004 - 11:44 AM
ta very much!
Posted 07 July 2004 - 07:13 PM
and the oil pump is not the same
