There are some technical facts about wheel diameters & widths which apply here.
First of all, the Mini was designed to have 5-20 x 10 cross ply tyres which translated into 145/80 x 10 radials. This allowed the tyre depth to do quite a lot of the suspension work and it worked well.
The 165/70 x 10 tyre performed the same function as the sideway depth was almost identical. The 165 tyre width gave better road-holding in the dry and in the wet the later compounds used in the 165 combined with better tread patterns meant they were virtually as good in the wet.
Then, to suit the Rover stylists the 13" wheel was introduced with a 175/50 x 13 tyre. Thus the suspension work previously done by the tyre depth could no longer happen as designed. The wider tyre is better on a very smooth and dry road, but in the wet or on a slippy surface it will not be as good due to reduced contact pressure. Ideally with a 13" wheel and 175/50 tyre the ride height should be increased and the damping softened to try to replace some of the suspension travel.
Now, moving on to wheel width, the original and never altered steering geometry was designed for a 3.5" wide wheel with a 5-20 or 145 section width tyre. Any increase in the nominal track will alter the geometry away from that as designed. It is known as altering the 'scrub angle'. With a 4.5" wheel it is only a small issue, but when wheel widths increase to 7", the overall effect is an increase in effective track of 3.5" and that is a lot. Thus the steering geometry is 'screwed up' with consequent deterioration in handling, although dry road-holding may still be reasonably OK, especially on a smooth surface. Racing cars running wide sticky slick tyres will have good road-holding because the stickiness of the rubber beats the steering deteroriation, but that's not applicable to road cars.
The choice is the owner's, of course, but no amount of B.S. can overcome the basic engineering factors which is that a Mini will always handle best on narrow small diameter wheels with 145 section tyres.
Incidentally, there is a 165/55 x 13 tyre available which would run on a 4.5 x 13" wheel with standard datum offset. I wonder if anyone has considered this as a compromise.
Edited by Cooperman, 29 July 2014 - 10:32 PM.
