Edited by Richie83, 01 August 2014 - 09:32 AM.
Using Spare Fuse For Alarm Wiring
Posted 01 August 2014 - 09:31 AM
Posted 01 August 2014 - 09:59 AM
You should have on the 24 fuse box car UK spec
19 20 Not used
20 15 Not used
21 10 Not used
22 20 Not used
23 Not used
Not sure if the Jap spec is the same? but look into where the blade fuse fits and see if you have 2 terminals, I doubt you will have as you usually have the feed either switched or live and a empty space where the circuit is empty. so you need to have the correct small terminals to solder onto your new circuit wiring, then pop it into the box and insert the fuse and onto the additional component.
If you do have the 2 contacts but no fuse identify which is the live feed in and the other side will be your wiring out to your circuit on the alarm.
Or make a new feed from the starter solenoid main wiring take off and fuse it accordingly.
Edited by KernowCooper, 01 August 2014 - 10:00 AM.
Posted 03 August 2014 - 04:29 PM
19 has something in it. I think it's for a 12 volt socket. Others are free but don't have connectors in them. Can I pick these up at Halfords or similar and push them in?You should have on the 24 fuse box car UK spec
19 20 Not used
20 15 Not used
21 10 Not used
22 20 Not used
23 Not used
Posted 03 August 2014 - 04:37 PM
I doubt Halfrauds but try AES
Posted 03 August 2014 - 04:59 PM
thanks for your help. I amI doubt Halfrauds but try AES
Useless with stuff like this 😄. Is this the type of thing? http://www.autoelect...ct/4/category/2
Posted 03 August 2014 - 05:05 PM
No they are these type normally at the bottom of the page, check the size of your holders or give them a ring http://www.polevolt....se_Holders.html
Posted 03 August 2014 - 05:55 PM
Ace, I'll go and measure. So will I have to wire in a live connection from the car to one side and then wire out the alarm on the other?No they are these type normally at the bottom of the page, check the size of your holders or give them a ring http://www.polevolt....se_Holders.html
Posted 03 August 2014 - 06:34 PM
There maybe a common feed on the rear of the fusebox you can use then through the fuse and onto the alarm
Posted 03 August 2014 - 06:57 PM
great. I'll whip it off and take a look tomorrow. Thanks for your help.There maybe a common feed on the rear of the fusebox you can use then through the fuse and onto the alarm
