1967 Mk1 Cooper S 1275 Replica Value For Insurance
20 replies to this topic
#1 dgear1984
dgear1984
  • 287 posts
Posted 01 August 2014 - 06:29 PM
Ok before we start, I have not intentions of selling the car, valuation is purely for agreed valuation so please no offers to buy it, thanks.
I would like a valuation of the car listed below so that I can get that valve added onto my insurance, the company I am with lets me set an agreed valuation of my choice assuming its within reasons. It is currently insured as a modified mini built to cooper s spec. I asked the MCR to do it but they where not interested in the car as it was not a proper cooper s.
The car started life as a July 1967 mk1 deluxe auto, probably one of the last few mk1's made as it also had a lot of mk2 bits on the car such as boot lid, rear side windows etc..., it was used and abused until it came to me with a manual 998. I have since undergone a full restoration building it to a cooper s 1275 spec. I have also converted this car to dry for reliability and availability of spares. This car has been built using as many original parts as possible, although a few bits are modern repro bits, like the interior. I think the car is very close to a real cooper s spec, obviously without cooper s on the log book. Passed boths it mot's since rebuild with a clean ticket.
I am yet to rolling road the engine, still building some ST H4's for it.
Spec and pictures below. Thanks Dave
SHELL
1967 MK1 HYDROLASTIC SHELL FINISHED IN TARTAN RED WITH OLD ENGLISH WHITE ROOF.
DOUBLE SKIN MK1 BOOTLID
AUSTIN GRILL AND MOSTASCHE
STAINLESS BUMPERS WITH OVER RIDERS AND CORNER BARS
OPENING REAR QUARTER WINDOWS
BLACK AND SILVER PRESSED NUMBER PLATES
CHROME SLIDING WINDOW SURROUNDS
WHEELS/TYRES
MINILIFE SILVER 4.5JX10 WORKS REPLICA’S WITH THICK OUTER RIM AND STAINLESS STEEVED BOLTS
DUNLOP R7 167/70/10 WITH CLASSIC DUNLOP RACING CR65 STYLE  TREAD PATTEN
DRIVETRAIN
1128 4 SYNCRO GEAR BOX WITH 1040 LAYGEAR COOPER S RATIO’S
COMPETETION LAYSHAFT AND 4 PIN DIFF.
3.44 FD
HARDY SPICER OUTPUTS
COOPER REMOTE EXTENTION
ENGINE
1275 COOPER S THIN FLANGE 312 BLOCK AT +60 (1330cc)
COOPER S 480 CRANK AT 0/10
COOPER S 521 RODS
NURUL PISTONS (10:1 COMP RATIO)
PIPER 270 BILLET CAM SHAFT WITH LIGHTENED FOLLOWER
LIGHTWEIGHT STEEL DUPLEX PULLEYS
SPECIAL TUNING LIGHTWEIGHT FLYWHEEL, 270 BACK PLATE, AP BLUE COVER AND AP PLATE, UPRATED CLUTCH LEVER AND PLUNGER
COOPER S FORGED ROCKERS AND COMPETION SHAFT
12G940 1805 11 STUD HEAD PORTED/MODIFIED BY ROB WALKER
BOTTOM END BALANCED BY ROB WALKER ENGINEERING
FULLY UNLEADED
ANCILLERIES
STEEL WATER PUMP PULLEY
16 BLADE METAL FAN
COVENTRY RE-CORED RADIATOR
K&N FILTERS IN STANDARD TWIN CARB AIRBOX
TWIN HS2 CARBS ON AEG347 MANIFOLD
23D LUCAS DISTRIBUTER RECURVED FOR ENGINE SPEC
HA12 LUCAS COIL AND CHAMPION SPARK PLUG CAPS
13 ROW OIL COOLER
MANIFLOW STAGE 2 LCB
MANIFLOW 1.75 STAINLESS TWIN BOX CENTRE EXIT
POLYBUSH ENGINE STEADY
SUSPENSION
MINISPARES FAST ROAD RUBBER CONES
FIA APPROVED HI-LOWS
SEAM WELDED SUBFRAMES
NEGATIVE CAMBER REAR BRACKETS
NEGATIVE 1.5 CAMBER FRON ARMS
COMPETETION FRONT BUMP STOPS
KYB “GAS-A-JUST” DAMPERS
HEAVY DUTY ADJUSTABLE TIE RODS
MINISPARES UPRATED TIE ROD BUSHES
MINISPARES YELLOW FAST ROAD LOWER ARM BUSHES
BRAKES
INNOCENTI MK1 COOPER S BRAKE SERVO
COOPER S 7.5 DISC SETUP
EBC RED STUFF PADS
COOPER S SPACERED REAR DRUMS
AEROQUIP BRAKE LINES
STEEL HARD BRAKE LINES
TALL MASTER CYLINDER
AUTOMEC SILICONE BRAKE FLUID
INTERIOR
STANDARD MK1 COOPER S NEWTON INTERIOR RED / GOLD BROCADE
NEWTON MOULDED RED CARPET SET
MK1 HEAL MATT
LUCAS 608 DIPPING MIRROR
BROOKSPEED REPLICA DASH FOR SMITHS TACHO
PERIOD NOS KANGOL FRONT STATIC SEATBELTS
MK1 120MPH SPEEDO
SPINGALL “WORKS” STEERING WHEEL
MISCELLANIUS
AUTOSPARKS LOOM WITH BLUE AND YELLOW TRACE
NEWTON BOOTBOARD
GREEN WASHER JET HOSE
CLEAR GLASS LUCAS INDICATORS
GENUINE BMC TWIN TANKS
2331DDCC-B9F1-45D0-B327-99963AD30667_zps
36FFEC6F-44DF-49A2-A1D8-8716E780E225_zps
F63FFF5B-8060-4FA9-B026-559F6EA38083_zps
61877943-7149-4FDB-883E-4069DB5C2749_zps
C16CBA45-6B07-4A37-9DAC-4B52722FD3B5_zps
3BC2E469-021F-4AC5-9614-4454F9F33C32_zps
81835551-E055-4F6A-9C49-25E22BA63136_zps
0B32711C-873C-4787-931A-A3EFACF53ABB_zps
99B656D1-A1C2-4801-A97E-0D6F6D78A54A_zps
76172E38-9E8D-493A-BDD1-7570D2959740_zps
E5FB4A84-C995-4F20-BC92-029BDC5ED6A9_zps
06853A4A-9F2F-4749-8EF3-68A81907A8D4_zps
Edited by dgear1984, 01 August 2014 - 06:42 PM.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 01 August 2014 - 07:16 PM
I spy my gearbox
#3 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 01 August 2014 - 07:20 PM
its got to be £15000.
very nice
your to honest for your own good some dishonest people would have bought a v5 cooper s and passed it off for £30000
#4 dgear1984
dgear1984
  • 287 posts
Posted 01 August 2014 - 07:36 PM
I spy my gearbox
Bits of it :-)
#5 dgear1984
dgear1984
  • 287 posts
Posted 01 August 2014 - 07:38 PM
very nice
Thanks,
I would rather be honest, you can't get caught out that way....
Still got a lot of finishing off jobs to do but its 95% there
#6 Cooperman
  • 23,566 posts
Posted 01 August 2014 - 07:50 PM
What a beautiful car and it's a credit to you.
To me it is a real Cooper 'S'. It is to full cooper 'S' specification & configuration and if used in competition it would be classed as an 'S'.
Value? I reckon £20k plus.
By the way, be careful with the 16 blade fan. They were notorious for causing overheating on the 'S' at high cruising revs as the 16 blades then suffered from 'discing, also known as 'cascade effect' where there are so many blades they effectively turn into a solid disc. The thing we used to do in the 60's was to fit a 4-blade fan (later a 6-blade Export fan).
#7 Clubber Lang
Clubber Lang
  • 746 posts
Posted 02 August 2014 - 04:22 PM
I would agree £15k is all its money if it was to be sold. Amazing the difference a log book makes. I can't see it being worth £20k to be honest as only the purists and enthusiasts will invest that kind of money and not on a re-creation IMHO.
I sold my 65 mk1 in March which was a similar build and condition(concourse). I sold it as it was too nice for me to use and I wouldn't take it out if there was any sign of rain lol! I didn't get back any where near what I spent on it but close to my estimation above.
 All that said it would be difficult to replace as its a one off.
#8 Alex_B
Alex_B
  • 4,573 posts
Posted 02 August 2014 - 04:55 PM
I was under the belief you over valued a car by a little bit for insurance valuation purposes? I would probably be trying to get it agreed for about £20k+ or near to that and seeing what the insurers say. But that is one beautiful car you have there!
#9 blacktulip
blacktulip
  • 6,231 posts
Posted 02 August 2014 - 08:17 PM
wow, what a car!!
#10 Carlos W
Carlos W
  • 10,115 posts
Posted 02 August 2014 - 09:29 PM
Lovely to see a car in that condition on the right plate too many MPis out there on 60s and 70s plates.
The car would be very hard to replace or recreate so the value should reflect that.
#11 Clubber Lang
Clubber Lang
  • 746 posts
Posted 03 August 2014 - 10:15 PM
for insurance I would say £20k
#12 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 04 August 2014 - 12:06 AM
For an insurance valuation, I would start at something silly like the high £20s, and see what they come back with.
#13 dgear1984
dgear1984
  • 287 posts
Posted 11 August 2014 - 10:10 AM
Hi,
Thanks for all the replies and compliments.
I think ill try for 25K and see how we go, hopefully I will never need to use the insurance.
Thanks Dave
#14 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 11 August 2014 - 04:54 PM
David were did you get the chrome arch trim from as it look very well. Im told that some is of lesser quaility
#15 dgear1984
dgear1984
  • 287 posts
Posted 12 August 2014 - 08:56 AM
Got it from minispares about 3 years ago.
It's not very easy to bend round the tight radius but I got it fairly good in the end
