Electric Fuel Pump Wiring
Posted 01 August 2014 - 10:10 PM
What's the best way to do it
I don't want to use a oil pressure switch to wire it up
I just want to use a relay , and dash switch
Posted 01 August 2014 - 11:12 PM
Erm, you've pretty much answered your own question. Switched feed from somewhere (or permanent live) to relay. Same with switch. Couple of earths and you're done
Posted 01 August 2014 - 11:22 PM
Hi
you dont need a relay
the pump should only draw 3 amps max
Posted 02 August 2014 - 02:47 AM
Posted 02 August 2014 - 07:01 AM
Its your choice but you should consider a way of isolating the power feed in the unlikely event of a serious accident, remember you or your passengers may not be able to turn off the power switch or turn off the ignition. If your not using the oil pressure method consider an inertia switch - http://www.minispare...|Back to search
Posted 02 August 2014 - 09:10 AM
I have just finished wiring for mine. Have run a switched feed through an inertia switch and then on to pump. Also wired from the third pin on inertia switch to a spare warning light in my centre binnacle so i can see if it trips
Posted 02 August 2014 - 04:16 PM
I went down the inertia switch route for safety to cut off the fuel in the event of an accident as "the Principal" said.
Whilst rebuilding my car, I fitted a wiring loom that had the heated rear window supply and used that as my car is a MkIII and doesn't have this type of window.
It was then quite easy to make up a small custom loom to run from the inertia switch down through the bootfloor and onto the pump.
I mounted the switch high up vertically on the rear seat backrest panel on a home made bracket.
These inertia switches can also be used as a secondary security device against theft.
If you leave the car parked, just tap the switch to trigger the device then lock the bootlid. If an attempt is made to steal your car, the thieves won't get far!!!
On your return, simply reset the switch and off you go!!
Cheers, Steve.
Edited by Stevie W, 02 August 2014 - 04:20 PM.
Posted 02 August 2014 - 06:09 PM
ground (pump)
Live from pump to ignition live
Switch from ignition live
And switch ground
Have I got that right or am I we'll off to be honest I just want to wire it up simple as possible just to get the car started after the engine rebuild so I don't need to worry about a cut off at the moment
Posted 03 August 2014 - 07:28 AM
Posted 03 August 2014 - 07:55 AM
Posted 03 August 2014 - 08:17 AM
Ign live to one side of switch
Other side of switch to +ve pump wire
-ve pump wire to earth/ground.
Ideally a suitable fuse should be in the feed from the ignition live.
As said, inertia switch or oil pressure switch is also worthwhile for your safety.
Posted 03 August 2014 - 09:03 AM
Cut off switch I will fit later on I just want the pump to work to start the engine up and time it up
And ignition live I'm going straight from the fuse box so I shouldn't need to fit a fuse should I ??
