Mk2 Mini. What Can I Do With It?
Posted 18 August 2014 - 06:28 PM
I used to use it for 12 cars and scatters but it's going to have decent paint this time. I wondering about autosolo and hill climbs. What do I need to know?
Posted 18 August 2014 - 09:38 PM
You should be able to get away with running it in one of the road going production classes in sprints/hillclimbs (you'd need to check the MSA Blue Book to check on the discs, but as Mini's had so many permutations as standard even if they weren't 100% legal for your particular model I doubt you'd ever have any problems - on line Blue Book is here : http://msauk.org/sit...sp?article=1176 ). In those classes you don't need to do anything to the car as long as it's taxed, MOT'd & insured other than put some yellow tape on the battery negative earth & mark the ignition switch on/off.
You do need an MSA National B non race comp. licence, & approved helmet, fireproof suit & gloves. Most people go for fireproof boots too but they're not mandatory. You'll probably need to join the organising Motor Club of your first event, but if subsequent events are part of the same championship you'll usually be able to use that membership for those. Otherwise you'll likely again have to pay the organising clubs membership fee (usually only about a tenner)
HTH
Keith
PS hillclimbs & sprints are great fun & very adictive!
Posted 19 August 2014 - 11:17 AM
There is also road rallies (daytime historic or night) again you only need to carry warning triangle, spill kit, put yellow tape on the earth lead and it is recommended to carry a first aid kit.
No need for a roll cage under the rules just a Nat B non race comp. Licence.
I would strongly recommend a sump guard though.
Posted 19 August 2014 - 09:27 PM
Posted 21 August 2014 - 06:43 AM
