How Much Arch / Mudguard Overhang
5 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,744 posts
  • Local Club: Exmoor Minis
Posted 21 August 2014 - 10:28 AM
Hi;
Just fitted replacement outer Arches to my Mini (Welded to the Inner Arch with the Rear Shock Support).
Before I start Painting I need to know whether and how much by, do the Arches / Mudguards overghang or should the be ground flush with the boot floor front and back?
Mine overhang at the front:
On the rear LH side I have 20mm at front and 5mm at the back, on the RH side I have 10mm at the front and 15mm at the back?
#2 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 21 August 2014 - 09:01 PM
Anyone?
#3 rally515
rally515
  • 3,848 posts
Posted 21 August 2014 - 09:36 PM
It is supposed to be fluch with the closing panel, but not seam welded in, just spot welded with the closing panel and then seam sealed, it might be a better idea to seam weld over but you've got t think somewhat longterm as to how easy it'll make it for a replacement closing panel/ arch.
#4 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 22 August 2014 - 08:55 AM
I'll grind it back flush with the closing panel and seam seal inside and out, what about the rear is that flush with the Boot Floor?
Not a good picture sorry:
Edited by JonnyAlpha, 22 August 2014 - 08:59 AM.
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 22 August 2014 - 09:02 AM
Mine was overhanging the boor end and flush the other IIRC, I don't think it'd matter too much that it isn't.
#6 rally515
rally515
  • 3,848 posts
Posted 22 August 2014 - 12:17 PM
If anything it's just a rust trap area, the inner arch lip that hangs down from the bootfloor has been rotted through in atleast one area one 3 minis I've had, might be best to grind them all flush and seam weld if you don't mind making that extra effort.
