Supercharger Advice
Posted 29 August 2014 - 06:46 AM
Posted 29 August 2014 - 11:05 AM
Carbs should match the power output/airflow of the engine, you should have an idea of that from charger and its drive ratio. Generally, you'll need less ignition advance but a rolling road session would be well advised.
Posted 29 August 2014 - 06:31 PM
What SU carb have you got? definitely get the car on a RR before you drive it any more.
Posted 29 August 2014 - 07:00 PM
Posted 29 August 2014 - 09:25 PM
Is it not good to drive it before having it on RR,all I know is the carb is standard from new and the car is a mini Tahiti 1275
Probably a HIF44 (which is correct).If it was me I wouldn't drive it. The timing might be way out. Also may be incorrect needle etc. Might have detonation, if its getting hot or the fueling is out. IMO
Posted 29 August 2014 - 09:39 PM
Posted 29 August 2014 - 09:59 PM
Should it not really generate heat into the cabin?,it was set up by a more than competant mechanic but from what I've read these do need a more specialist tuning?
Manifold could be getting v hot
Posted 29 August 2014 - 10:26 PM
Posted 30 August 2014 - 07:32 AM
Yes, it may actually be ok to drive as it is but you won't know that for sure until you check. I don't know about you but if I'd just built a new engine I'd rather pay 2-300 for a RR session that have the thought in the back of my mind that it could melt itself any second. Have a search around as to what detonation can do to heads and pistons on a forced induction engine. It isn't pretty. There are plenty of FI mini friends RRs around the country that will be able to help.
Apologies for the essay but I'm just trying to save you money in the long run!
Posted 30 August 2014 - 01:31 PM
Posted 30 August 2014 - 05:39 PM
Don't drive it until it's setup.
Posted 30 August 2014 - 10:41 PM
Posted 30 August 2014 - 11:04 PM
Throttle disc
Throttle spindle
Rubber seals like the spindle seals and choke seals if a hif.
The jet
The piston and chamber are within tolerance.
Float chamber needle and seat.
All of the above can be fixed with a kit from burlen.
You no doubt will need stronger throttle return springs.
Stronger dash pot piston spring or maybe even two and a custom needle.
No doubt some timing either mapping of adjusting. IMO you shouldn't run a forced induction engine with a dizzy, mapped ignition is a must if you want to keep your pistons from growing holes....
