Multimeter
Posted 01 September 2014 - 07:57 AM
Posted 01 September 2014 - 01:16 PM
Here is the full circuit with the wiring colours in the picture for you.
Posted 02 September 2014 - 01:29 AM
If you haven't used a multimeter then what you want to do is use the voltage function, and remember that what a voltmeter is measuring is a difference between two points. Since it's measuring differences, if you put a volt meter on something at 6v and something else at 12v, the meter will show 6v - the difference. That's what they do.
So if you put the positive (red) probe on the live wire (according to the colours on your diagram) leading into the headlamp, and the negative (black) probe on any sort of earth connection, you expect to see battery voltage ~12v.
If you get zero, then that means you have no voltage arriving there, so go back to the switch and do the same thing, probing the wire you expect to be live, and referencing against any convenient earth point. I use exposed screw and bolt heads a lot when I need an earth. Anything that will form an electrical pathway to the car body, which is grounded.
If you get voltage at the switch but not the lamp, the issue is between those two points, though to be far if that was happening you have a short, and it likely would have blown a fuse anyway.
If you have nothing at the switch, go back to the fuse block, working your way back till you find voltage. Then look at what might be stopping it getting further.
Have fun, be patient.
