Hibernation
Posted 01 September 2014 - 09:39 PM
Posted 01 September 2014 - 10:26 PM
Mine hibernates too, but right through to Spring. Ideally, you want to make sure the battery is kept nice and charged. I've got a CTec MXS 3.6 trickle charger that you can leave plugged on to the battery whilst it's still in the boot. It's great because you need to be able to start it every couple of weeks and move it back and forth to prevent anything seizing up. Somerford Mini's also do a great car indoor cover for about £40.00 which is breathable and really helps to stop the build up of grime which just accumulates in garages. But the battery charger is a must. It's about £50.00 but well, well worth it.
Posted 01 September 2014 - 10:31 PM
Welcome to TMF by the way
Posted 02 September 2014 - 12:03 PM
Hello Kyle welcome to the forum, I'd go with everything miniminx has said starting it up every couple weeks, moving back and forth to prevent any issues/seizing. November is only a couple months away too lucky you!!
We look forward to seeing pictures of your mini soon shout if you need anything
Edited by Devo, 02 September 2014 - 12:03 PM.
