Gap Between Clock Binnacle And Top Rail
10 replies to this topic
#1 TheJack
TheJack
    Formally known as Jackocola
  • 531 posts
Posted 02 September 2014 - 05:09 PM
So I decided to take off my top rail cover as I am going for a mk1 looking outside and in, I successfully removed it and now know I have some work to do to tidy it up. Dent in the ashtray hole due to bolt being stuck. I am worried about the gap between the top rail and the binnacle of my clocks...any suggestions?
#2 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 02 September 2014 - 05:39 PM
Convert to a centre binnacle speedo, as fitted to those models that didnt have a padded upper dash rail as standard, thus getting rid of the twin pod clocks and the gap. It will help with the retro look that you're trying to acheive too.
#3 jpw1275
jpw1275
  • 2,803 posts
Posted 02 September 2014 - 05:47 PM
As said above
#4 TheJack
TheJack
  • 531 posts
Posted 02 September 2014 - 05:50 PM
I would love to convert it to a centre speedo but it's more money :/ just ordered a mk1 grill and surround with some bits as it should be getting painted soon and the liner for the dash is new and the clocks, binnacle and bracket aren't that old either  :unsure:
#5 splintercat
splintercat
  • 616 posts
Posted 02 September 2014 - 06:57 PM
Go for it mate centre Speedos are pennies here or flea bay.
Even with the plastic centre pinnacle and it will sort out yer dilemma. And as far as the rewiring goes it's a piece of cake......Must be as l managed to do it lol
#6 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 03 September 2014 - 01:22 AM
As above used centre binnacles are relativley inexpensive and readily available, you'll also need a centre binnacle dash liner, speedo cable and centre binnacle wiring loom/harness too (if you don't want to cut into/convert the existing one). None of these are particularly expensive and you could always sell your existing liner and instrument cluster/bracket to help fund the purchase. If this isn't possible though, then perhaps you should consider refitting the padded upper dash rail until such time that you have the funds to convert to a centre binnacle. The later speedo pods mounted behind the steering column were never designed to be fitted below an exposed upper dash rail and as such I think you're probably going to struggle to make one look presentable without a padded dash rail above it.
#7 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 606 posts
  • Local Club: Birmingham Mini Owners
Posted 09 October 2014 - 11:49 PM
Very interesting peeps and good news as I have just purchased a centre binnacle from that certain auction site myself. One question, as I haven`t yet set about stripping the dash out, can a 3-instrument binny go straight in with the padded top in place or will that have to go? I`m glad to hear the rewiring is "a piece of cake", not my strong point. Oh.....someone mentioned needing a speedo cable - does the one going to a 2-instrument cluster not fit?  :ohno:
#8 Marco1972
Marco1972
  • 822 posts
Posted 10 October 2014 - 07:00 AM
It's a different cable fairly inexpensive from mini spares
The difference is it has a screw on end as a pose to the White plastic clip that the later instrument pack had its also a different length
#9 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 10 October 2014 - 08:42 AM
i see you have after market  dash liners in cream, you could speak to the manufacturer of them and ask if they can make you a matching top cover for the dials.
#10 splintercat
splintercat
  • 616 posts
Posted 14 October 2014 - 12:45 PM
The padded top rail will have to go looks s.it with it and the centre binnie just won't fit right.
Rewiring is a doddle there's a thread on here or if not lll send you the info for it.
As for the Speedo cable...different lengths and different fittings so you need to buy a the right one.
It'll be worth it though.
#11 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 606 posts
Posted 14 October 2014 - 07:39 PM
Thank you Splintercat, would you send me the info please? I`ll feel happier going in "armed" so to speak. Minispares is 2 miles down the road from me so I have no probs from that point of view. As an aside - I love your cat, he looks just like my Fred, a rather large ginger tom and top-Cat amongst my family of four.
