Hi.
As always on the week leading up to a rally the car has decided to get nervous and have a problem!!!
Clutch won't allow me to engage a gear - or it will, but only with force and then with the clutch pedal still down it is dragging.
Clutch pedal is a bit spongey at the top of travel so assume air is getting in somehow.
How can i tell if it is the master or slave cylinder at fault????
No fluid is being lost which is the normal indicator that the master has corroded and fluid is leaking past - and no fluid on clutch pedal either.
When i ask my assistant (wife) to put her foot down on the clutch, then place a screwdriver between the throw back bolt and the lever, then when she pumps again the lever moves a bit more - probably the 'bit more' i need.
The slave cylinder bleed nipple was loose ish in its hole and i suspected this was leaking fluid in so wrapped it in PTFE and put it snuggly back in and it did seem to solve the issue at first, but now the clutch isn't working again.
Obviously i can go out and buy a slave cylinder tomorrow and fit tomorrow night BUT if it is the master i need to get one ordered ASAP as i've got scrutineering Friday night!!!!
Any advice or hints....???
