Could Someone Help Me With A Measurement Please?
Best Answer vkasiotis , 03 September 2014 - 06:09 AM
we do not use inches metric. hope it helps u
126.9 cm 127cm 127.1cm
back      midl         front
Go to the full post
7 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 02 September 2014 - 08:01 PM
Hi everyone.
I wondered if someone had an unmolested shell that they could take a few measurements please.
I would like to know the measurement between the passenger and driver side door step lip (the bit the rubber door seal goes on)
Taken from the bottom with the hook of the tape measure hooked onto the lip one side and the measurement taken to the lip on the other side.
I would need the measurement in the middle of the step, at the front of the step (just before it curves up) and the back of the door step (before it curves up)
Think that's clear enough.
I'm very grateful.
Ben
#2 vkasiotis
vkasiotis
  • 38 posts
Posted 03 September 2014 - 06:09 AM   Best Answer
back      midl         front
Edited by vkasiotis, 03 September 2014 - 06:11 AM.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 03 September 2014 - 11:08 AM
Thanks, ill have a measure soon!
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 05 September 2014 - 05:27 PM
back      midl         front
I tried these measurements and they are way off. Think i didn't explain it clear enough.
Here are some more pictures of what i mean.
You can see, mine measures 270cm at the back before where it curves up.
Ben
#5 NZMini1275
NZMini1275
  • 227 posts
Posted 05 September 2014 - 07:20 PM
Reads around 135 to me unless you have the widest mini ever haha :)
Those tapes are way to confusing to use
#6 NZMini1275
NZMini1275
  • 227 posts
Posted 05 September 2014 - 07:23 PM
I only work in millimetres
I'm away for a few days so hopefully someone else can measure theirs for you
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 05 September 2014 - 08:00 PM
My bad! Can't even use a tape measure properly  :shy:  :withstupid:
It's been one of those days for a few days now.
Thanks for pointing it out. It actually reads 127cm which is obviously 50" It says quite clearly on the tape measure.  >_<
Oh well. I know where i am now!
Thanks alot.
Ben
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 05 September 2014 - 08:07 PM
so thanks vkasiotis, your measurements are spot on. I'm just an idiot!
Still on the plus side, i just measured mine and they are mm perfect to yours which is all that matters!
Thanks alot
Ben
