Audio Help Before I Cry! !
13 replies to this topic
#1 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 07 September 2014 - 06:57 PM
So i have a couple of amps and quite a few speakers.
The problem is i have a buzzing when i start the engine...which speeds up as i rev if that makes sense.
Any ideas what would cause this?
#2 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 07 September 2014 - 07:07 PM
interference from the engine i had it from a broken earth check to see if the engine is earthed properly if it is try cleaning it if that doesn't do anything then try getting some ferrite clips and put them on the cables for your amps.
#3 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 07 September 2014 - 07:18 PM
One of my amps is earthed to the negative terminal on the battery...is this good/bad/problematic? Just it seems since the addition of this amp the problems started. But it could be in my head.
Tbf, ive got a couple of weeks off. Might rewire the whole thing.
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 07 September 2014 - 07:22 PM
earth it somewhere else and see if it stops the problem if not then try what ive suggested if it does you're sorted :)
#5 Anthony30
Anthony30
  • 1,466 posts
  • Local Club: N/A
Posted 07 September 2014 - 07:26 PM
Have you tried using a suppressor that connects to the ignition coil? :unsure:
#6 humph
humph
    How bad can it Be?
  • 1,065 posts
Posted 07 September 2014 - 07:28 PM
Have you set the gain on the second amp? I believe having. The gain set too high on the amp causes buzzing from other electrical items. I'm no ICE expert though
#7 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 08 September 2014 - 09:10 AM
Alt whine... when it happens its a nightmare.
What mini is it? Carb/points, SPi or Mpi?
Are you running R spark plugs?
Are your engine ground strap in good condition?
Have you tried powering down the amp to see if it both or just one.
if its both it could be coming from the headunit, using a phone mp3 player with a 3.5mm jack to RCA lead to just the amps singnal can show if its the headunit of the amps themselves.
#8 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 08 September 2014 - 12:12 PM
I just been and bought a new earth strap so well see how that goes. Its a carb engine.
#9 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 08 September 2014 - 12:43 PM
I would start with getting a set of the right NGK 'R' plugs.
#10 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 08 September 2014 - 02:02 PM
What are the 'r' plugs?
The plugs i have are ngk...
#11 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 08 September 2014 - 02:03 PM
Also i have an amp in the boot and one under the drivers seat. Is there and good places already available to earth there? Or am i drilling holes in the floors?
#12 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 08 September 2014 - 02:22 PM
in the boot to the parcel shelf or seat back plenty of nuts and holes to use..... under seat possibly the cross member or seat lock loop?
#13 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 10 September 2014 - 04:08 PM
This is the first job I'd do....
#14 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 15 September 2014 - 08:19 PM
Where would i get one of these suppresors from?
