When Rover Went Over I Was Not Really Paying Attention To The Mini Engine....
Posted 21 September 2014 - 11:27 PM
In that lets say I was going to start fresh on a new motor what might I not know?
One thing I am already thinking is to loose the dizzy but. Then we could do that years ago I just never did.
Or is it all much the same?
Posted 22 September 2014 - 08:20 AM
First decide what you are going to do with the car when you've finished it, and that'll determine what you should do with the engine...
ie, there's no point having an all singing and dancing high performance engine if all you're going to do is go to the shops and back in it...
likewise, if you want to do track days or take it round the 'ring there there's no point building something which is only good for going to the shops and back.
Choose 2 of the following 3 things...
Cheap
Performance
Reliability
Posted 22 September 2014 - 09:11 AM
so what did they do to the engine and ancilleries that might have made things better for us racers?
does that make the question clearer?
so that rules sout SPi and MPi but was thae block changed?
main caps changed?
better water pumps oil pumps Timing chain?
or ........
Posted 22 September 2014 - 09:18 AM
Well, if you go to the extreme of a miglia or Mini Se7en engine, spend about 20k on replacing everything but the block, head and gearbox castings.
Forged cranks, H rods, high spec pistons, timing belts, lightweight clutches, 7/8 port heads, dog boxes, ATBs LSD 's etc etc, throttle body injection, mappable ignition, turbo/supercharge
It all depends upon your budget
Posted 22 September 2014 - 09:22 AM
ok so you cant answer my question.
fine.
i guess the Avatar does not give you a clue?
yes been there done that with the A and A+ but had nothing to do with any of the latest stuff so wanting to know what Rover changed in the Basic design that we can take Advantage of.
Or do i stick with my all singing and dancing A Motor?
Posted 22 September 2014 - 09:44 AM
Unfortunately, answering a question which is as vague as the one you have asked is very difficult...
Essentially the A+ engine which was used in the last of those produced is almost identical to the one which was first produced in the early 50's
There are very few changes/differences to the actual A(+) series engine throughout the years of production.. mostly done for strength as the horsepower of the engine raised from 20-30 for the original 800's and 950's to the 1275 turbo which ran 90hp from the factory...
There were minor modifications, with the introduction of the MPi with the filter moving to the block ( but this had already been done many years before with the Maestro/Montego installation of the A+ engine )
So I fail to grasp what your question is...
What can you do to an A series today.... sh*t loads
as I said, Turbo, Supercharger, 16v heads, BMW K RS1200 heads, Dry decking really anything you can dream, vs anything you can afford.
You don't even have to stick with the A(+) engine, put an Yamaha R1 engine in the front, or a couple of Hyabusa Turbo's in the back...
Posted 22 September 2014 - 10:05 AM
Doesn't to me - all I can see is a black Mini. Could be a race, rallycross, rally or even an autograss car...!!
Posted 22 September 2014 - 10:26 AM
right so nothing new.
all i Need to know.
Posted 22 September 2014 - 12:00 PM
PS the MPi did not use a dizzy either, or mechanical petrol pump, so no holes for these in the block either...
If you want to build a good engine start with a mid 80's A+ engine, best metal.
Posted 23 September 2014 - 10:54 PM
