Was it the expansion tank what made you ill ?....I can't say the B word
thats the one.
fitted
Posted 08 July 2018 - 07:19 PM
loads done today as i have been able to sit in the car. readjusting parts of the mirrors which involved bending things and new paint.
then there was the liners for the foot well i have been meaning to do for years.
as normal measured, made templates then forgot the corners were not all the same. make again opps wrong side make again. polish. tried polishing checker plate nightmare.
fitted.
Posted 09 July 2018 - 08:03 PM
a little job this evening that i had been putting off for a while. removing some stickers from the polycarb side windows.
and they always leave some sticky residue and they had been on for about 21 years.
the solution
something that is also sticky
gone
the other side
a bit of polish to remove the outline
Posted 10 July 2018 - 09:09 AM
So did you just use masking tape to sort the residue? I need to the same with my rear quarters
Posted 10 July 2018 - 09:22 AM
basically just press remove repeat until gone. you will need to change the bit of tape a few times. it is just using a sticky thing to pull the sticky stuff off. did not want to use any solvent for many reasons. the rubbing and possible more scratches ..
Posted 10 July 2018 - 11:55 AM
spot on cheers mate, yeh totally with you on the solvent side as have been there done that with some over spray a couple of years ago. they went from clear to milky fubared
Posted 10 July 2018 - 12:17 PM
spot on cheers mate, yeh totally with you on the solvent side as have been there done that with some over spray a couple of years ago. they went from clear to milky fubaredbasically just press remove repeat until gone. you will need to change the bit of tape a few times. it is just using a sticky thing to pull the sticky stuff off. did not want to use any solvent for many reasons. the rubbing and possible more scratches ..
Posted 25 July 2018 - 08:38 PM
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
