I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
878 replies to this topic
#511 nicklouse
  • 17,944 posts
Posted 20 October 2018 - 08:10 PM
needs more
#512 InnoCooperExport
InnoCooperExport
  • 371 posts
  • Local Club: Mini Seven Club Nederland
Posted 16 November 2018 - 11:20 PM
Looking great Nick!
#513 nicklouse
  • 17,944 posts
Posted 18 November 2018 - 08:02 PM
winterising the daily and in the unit and one of my neighbours drops these off.
#514 nicklouse
  • 17,944 posts
Posted 07 January 2019 - 09:54 PM
while back in the UK i collected a few parts.
not actually sure that this will fit due to the oil system.
a full length pipe to the back of the car so i can add a cat where i can
and then some parts to make the rear box from some where a bit more local.
unfortunately they dont seem to have quite flared the input part correctly but as they are not welded in i should be able to fix that.
#515 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 09 January 2019 - 07:41 PM
needs more
ill send you a migliacars one if you want
#516 nicklouse
  • 17,944 posts
Posted 12 January 2019 - 09:26 PM
mmm i think i always knew this was not going to work
oil system in the way.
at least i can mock up the new exhaust with Kat and use the existing LCB.
#517 imack
imack
  • 1,872 posts
Posted 12 January 2019 - 09:50 PM
Blimey, that really is in the way isn't it, you're going to need a lot more room than that.
#518 nicklouse
  • 17,944 posts
Posted 12 January 2019 - 10:09 PM
might sell it on or keep it for a different build. but again keeping the Medium size LCB with a larger pipe may also be ok as the gas velocities will still he high and the Kat should not be too much of an issue.
#519 GraemeC
GraemeC
  • 7,314 posts
Posted 13 January 2019 - 08:20 AM
Could you do the oil connection with a banjo and get it much tighter to the block?
#520 Becko
Becko
  • 13 posts
Posted 13 January 2019 - 11:11 AM
Just read this from the start ... excellent... keep the posts coming ... I really need to make a start on my minus
#521 nicklouse
  • 17,944 posts
Posted 13 January 2019 - 01:01 PM
If I recall there was a very good reason for not doing so on the block and that was every direction needed the hose to bend away from the surface due to the flanges. It could be done hard lining it for a distance but then that would really need mounts.
Another option would to have the outlet and inlet both on the box.
#522 imack
imack
  • 1,872 posts
Posted 13 January 2019 - 01:30 PM
I'd have thought you've got even less room to play with at the box.
I've never seen a pre-pump filter setup, I presume the takeoff is from the standard oil pick up pipe mounting point at the back of the box.
#523 GraemeC
GraemeC
  • 7,314 posts
Posted 13 January 2019 - 01:54 PM
I would've though having both on the box would be difficult too, unless you reworked the pick up so the feed 'to' the external filter was somewhere else and used the old pick up location to return.
#524 nicklouse
  • 17,944 posts
Posted 13 January 2019 - 04:08 PM
a few guys have taken the pick up out of the front of the box not seen where it goes back in though but i guess back of the box where mine comes out or where mine goes in but as he has been running his 8 port for years and most likely did it to match the exhaust  he was running.
box side is ok
routing has changed since these pics
hindsight is great i should have asked for pics like imacs show.
#525 nicklouse
  • 17,944 posts
Posted 13 January 2019 - 04:15 PM
todays tools were these
 new pipe fitted to old LCB ready for cutting for Kat etc.
