I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
878 replies to this topic
#556 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 24 May 2019 - 07:14 AM
Nick, I just had a look on the Polestar site - they seem good value. Would their ECU's be suitable for an MPI mini if my modifications end up going beyond the limit of the MEMS system? I've previously discounted changing the ECU as it looked like a very expensive affair using some of the big brands.
I think I'll be ok with my current spec, but depending how much I eat into my budget I may look at a replacement head and other options further down the line.
#557 nicklouse
  • 17,934 posts
Posted 24 May 2019 - 07:28 AM
seriously your best bet is to mail Neil, but I would say yes as it odes mention the Mini injection as being ok with it. also this was developed with the A series in mind from the start and has then been expanded to add other engines as needed. please note the prices shown are not current.
#558 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 24 May 2019 - 07:43 AM
Gotcha, thanks. Yes, I will drop them a line to discuss if I get beyond the limits of the MEMS.
I'm surprised I haven't heard of them before, when you look at what people spend with SC and the like. Thanks for sharing.
#559 nicklouse
  • 17,934 posts
Posted 25 May 2019 - 09:10 PM
right today has been fun.
first remove the old brackets that the amp and coil were on.
then find a suitable plate to mount the new coil pack on and making it less checker-plate and mount.
then onto the timing wheel and sensor mount.
as my timing cover was an A series which had a indicator added by me that needed adjusting. before i could get the wheel on. also what ever they coat them in meant it was an interference fit so take the centre back to metal and all fits.
then the sensor  mount. not fitting.it seems the bolts that are supplied are for the A+ where the 5/16 bolt they use is actually drilled through on those casings.
the bolt bottoms out on mine.
second time i have come across kit supplied that is not correct or does not provide info on what it fits or have any info with it as per fitting info or have fitting info on there pages.
what they need to understand is if we don't know how it is meant to be fitted then we will complain when it does not. end Rant.
roll on tomorrow.
#560 nicklouse
  • 17,934 posts
Posted 26 May 2019 - 07:33 PM
so. web sites read and it seems that what was sent does not match the website description. bolt length wrong and 2 washers missing.
2" bolt swapped out for a 1 3/4" one and thread locked in place.
 TDC worked out and marked tooth removed damper re fitted just need to torque the bolt down later.
access was not good so i had to pop the rad out. still best done on an engine out.
#561 nicklouse
  • 17,934 posts
Posted 28 May 2019 - 07:10 PM
new delivery. this is for a DCOE so i will need to modify the mount.
some pics of it on one existing mount. it is aligned but too high.
lower fixing will be interesting.
#562 nicklouse
  • 17,934 posts
Posted 30 May 2019 - 06:47 PM
ok bracket day.
first issue  angled surfaces and no passthrou for bolt heads.
so bolt head diameter reduced.
then spring tag added to the drive plate for the TPS
fancy bracket made up.
and fitted
and onto the car.
tomorrow is start the wiring.
#563 nicklouse
  • 17,934 posts
Posted 31 May 2019 - 08:23 PM
today has just been making connectors up.
photos of the connectors so i know what terminal what wire goes to.so only the terminals to do to the ECU and it should start.
#564 nicklouse
  • 17,934 posts
Posted 04 June 2019 - 09:58 PM
i hate wiring.
#565 nicklouse
  • 17,934 posts
done
#566 nicklouse
  • 17,934 posts
Posted 04 June 2019 - 10:00 PM
magic dizzy illuminated with different strength LEDs
https://youtu.be/uhZpYPsjgac
#567 nicklouse
  • 17,934 posts
Posted 08 June 2019 - 10:19 PM
spring sorted.
#568 nicklouse
  • 17,934 posts
Posted 09 June 2019 - 08:52 PM
as mentioned earlier the old crank damper had a crack in it.
#569 nicklouse
  • 17,934 posts
Posted 09 June 2019 - 09:18 PM
Moved the rad forward a bit thinking i might go back to a proper(ish) grill set up
and had it running as there was moxtlikely loads for fuel and oil in the pistons after playing with the carb and sutch.
https://youtu.be/jk_aP9VZJys
#570 nicklouse
  • 17,934 posts
Posted 10 June 2019 - 06:55 PM
today has been polish and polish and wax.
thinking i might put a grill back on it.
