I Decided It Was Time To Drag The Race Car Out And Update It.
#61
Posted 08 March 2015 - 11:14 PM
image.jpg 72.87K 27 downloads
And blocking off the air vert holes.
Put the rear beam in to check clearance.
image.jpg 60.2K 33 downloads
Some reinforcement to the subframe.
image.jpg 91.93K 33 downloads
Finished of the seat mounts.
image.jpg 39.46K 20 downloads
And then there is the issue of the rest wheel arches.
image.jpg 72.91K 58 downloads
As I don't want to burn the paint off again.
#62
Posted 15 March 2015 - 01:00 AM
As I am flattening the bottom of the car if I needed to make some form of brackets that will take the "floor"
First part went well.
image.jpg 76.33K 54 downloads
Then just layer the rods that will make the "floor".
image.jpg 102.24K 48 downloads
Then thought I had better check the frame still fits the shell.
Mmmm I might have a problem here.
#63
Posted 15 March 2015 - 07:25 AM
#65
Posted 18 March 2015 - 11:34 PM
#67
Posted 21 March 2015 - 07:53 PM
I use a slightly shaped drift.
Finished off the front subframe. Of to the blasters next week.
#68
Posted 22 March 2015 - 08:54 AM
#69
Posted 22 March 2015 - 09:03 AM
#70
Posted 22 March 2015 - 08:43 PM
#72
Posted 22 March 2015 - 10:02 PM
#73
Posted 23 March 2015 - 03:19 PM
That prurple carpet is pure sex by the way.
#74
Posted 23 March 2015 - 03:24 PM
That's all looking great, it's such an interesting build. I'll be trying to drift out my top arm bearings after a thoughrough decrease.
note the shape of the tool. it is not a bad photo it is shaped like that and grind a flat end too it.
less likely to slip. also on the side with the grease nipple take care that you dont hit it or the hole it is in as they are at about that distance.
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
Bing (2)
