Best Tool For Grinding At Edges Of Seam
rust repair
10 replies to this topic
#1 marcusw
marcusw
  • 59 posts
Posted 26 September 2014 - 01:15 PM
Hey,
Just a quick one, was wondering what people use to grind off welds etc at the ends of the external seams, so for example where the rear quarter panel meets the rear valance. (arrows in picture)
Attached File  Untitled-1.jpg   53.47K   24 downloads
As I cant get my angle grinder in there even with small discs on
I was thinking a dremel but not sure if there man enough
Marcus
#2 MrIan
MrIan
  • 125 posts
Posted 26 September 2014 - 01:25 PM
Yeah i'd use a dremel type tool.
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 26 September 2014 - 01:26 PM
A dremmel will do it with one of their mini grinding discs, may take slightly longer than a full sized grinder but is still a good little tool for those awkward little places.
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 26 September 2014 - 01:29 PM
It will work with a dremel but will take AGES!
You can get electric belt sanders which are ideal or use a carbide burr in a die grinder.
Ben
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,895 posts
  • Name: Neil
Posted 26 September 2014 - 03:00 PM
If you have a compressor then a high speed grinder and oval carbide burr is best. Failing that a dremmel.
#6 rowanxx
rowanxx
  • 29 posts
Posted 26 September 2014 - 03:16 PM
Something like this? http://www.screwfix....nder-240v/54960
Edited by rowanxx, 26 September 2014 - 03:31 PM.
#7 sonikk4
sonikk4
  • 15,895 posts
  • Name: Neil
Posted 26 September 2014 - 03:18 PM
Can't get that link to work. The problem with the belt sander is it will not go right into a corner, a dremmel or carbide bit will.
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Your link didn't work but this is what i mean..
#9 rowanxx
rowanxx
  • 29 posts
Posted 26 September 2014 - 03:32 PM
Edited my original link, there was a space after the url. Same thing as what ben_O has suggested.
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 26 September 2014 - 03:50 PM
I have an air belt sander which i used all the time when i was working as a panel beater. I found it very good at getting in all the tight spaces.
Just one thing worth remembering and that is to avoid putting pressure on the roller at the tip of the belt as it wares them out. If you must use the very tip of the belt, go easy with low pressure otherwise they wear quicker
#11 marcusw
marcusw
  • 59 posts
Posted 26 September 2014 - 04:27 PM
Ben
That looks like the tool I want,
looking at this : http://www.ebay.co.u...=item58981ceb3c
400w i guess should have enough punch
Not sure what bits to get though, it doesn't say which ones are suitable for steel
But thanks for the advice, Ben you seem to be every where on this forum haha
Have a good day
Marcus
Also tagged with one or more of these keywords: rust repair
