My Slightly Bent Mini 1000
Posted 05 October 2014 - 06:02 PM
IMG_20140809_131420.jpg 41.78K 105 downloads
So we started measure in and it turned out it was around 3 inches narrower than should have been so we pulled it as close as we could get
IMG_20140809_165912.jpg 49.3K 94 downloads
Luckily the body had split due to rust around the scuttle and top of the hinge panel I say luckily because if it hadn't I am fairly sure it would have pulled the roof down to not sure if the young fella driven would agree as I'm sure his feet prob didn't have much room left lol so we cut out the rotten bent metal and started Weldon and fitting new panels always measure in and test fitting before final welds IMG_20140831_153955.jpg 48.49K 35 downloads IMG_20140831_153940.jpg 38.88K 39 downloads
A lot straighter now wee kept going re skinned door new inner and outter cills
And sealed to prevent water getting in between panels
IMG_20140831_153949.jpg 25.29K 23 downloads IMG_20140921_151715.jpg 79.61K 57 downloads IMG_20141001_125856.jpg 62.9K 55 downloads
IMG_20141001_113654.jpg 44.31K 36 downloads
Now all we gotta do is fill and test fit arches and paint ano a lot of people would have replaced whole floors etc but to me a mini is about the smile u get while driving it I personally couldn cope with it in the garage for months to me its a strong straight car that with a bit of paint sport pack wheels and Monte Carlo arches it will look a treat will post more pics when painted
Posted 05 October 2014 - 09:32 PM
Posted 06 October 2014 - 05:57 PM
Posted 25 October 2014 - 06:34 PM
Inside of door will be painted and wax oiled later also got the door shuts painted
IMG_20141025_162054.jpg 49.76K 9 downloads
IMG_20141025_162105.jpg 48.7K 4 downloads
Then turned my attention to the height at the rear car was set as high as it would go looked w..k to me so dropped it to here
IMG_20141025_134454.jpg 71.15K 11 downloads
Hmmmm stepped back and thought no to low so put it up to here
IMG_20141025_162136.jpg 63.89K 15 downloads
IMG_20141025_162211.jpg 76.73K 41 downloads
I think its bang on father thinks its still to low what u think
Posted 26 October 2014 - 02:50 PM
Ride height looks good!
Nice Mini
Posted 26 October 2014 - 03:06 PM
Posted 26 October 2014 - 05:41 PM
Too low....
Any weight in the back you'll be rubbing the tyres...
I recommend you have at least 2" (50mm) between wheel and arch. if you're using standard suspension and just hilo's
If it's set as high as it'll go then you have the cheap knock off hilo's where the shafts are actually 1" shorter than they should be... get some new shafts made which are an inch longer and then you'll be able to set the suspension correctly
Posted 26 October 2014 - 05:56 PM
Hi I didn't take any photos of the suspension fully up she goes up a lot higherToo low....
Posted 26 October 2014 - 05:58 PM
as std there's about 4" between wheel and arch
Posted 26 October 2014 - 06:44 PM
Posted 06 December 2014 - 09:59 PM
IMG_20141206_150522.jpg 50.12K 18 downloads
Posted 27 December 2014 - 02:47 PM
IMG_20141226_135931.jpg 31.37K 8 downloads
No flash on my tablet paint is a little flat but is a good even finish will polish up a treat am happy its starting to look like a car again lol
Posted 27 December 2014 - 05:18 PM
What paint system are you using ?
Posted 27 December 2014 - 11:26 PM
Hi were using cellouse will post better pics when polished
Posted 27 December 2014 - 11:41 PM
looking good, interested to see how the celly polishes up.
