Hey guys,
When it rains (or if I pour water from under the check strap seal), within seconds water starts coming out from under the cross member section inside down the gap in the floor. I'm completely at a loss because there are absolutely no holes/gaps that I can see!
I've looked around on the forums and looked into oversills and that they should have flutes to allow water/air to circulate?
Is this correct?
My oversills look like this:
My concern is that, uncovering these holes would surely promote more rust will it not? It would mean moisture can get between the sill and the actual bodywork?
Water coming out from:
Edited by Pottrell, 19 October 2014 - 01:27 PM.
