Hello all
I am a long time observer first time owner of a ZCars mini.
I recently acquired a vtec road kit that has had an unscheduled meeting with a hard, flat surface.
I intend to build my 88 saloon and could use some advice on which way to go.
Here's my quandary.
The lower front tube of the engine frame, where the front torque mount and control arms mount, has a slight but noticeable bow in it, due to the forward momentum of the impact. The rest of the frame and roll cage appear to be true.
I believe that the frame can be repaired, but i have no measurements of a true frame. I have come across a couple of posts relating to frame specs and it appears to be a touchy subject (understandably) but as i am not trying to create my own from scratch, i'm trying to save one from the great scrapyard in the sky, someone my feel inclined to help out?
If obtaining specs turns out to be a futile venture then my other option would be to attempt to sell the frame and get a new frame from Zcars. Therefore some advice and or experience with importing a kit into Canada would be greatly appreciated.
