Hi all does anyone run there mini on super unleaded or a higher ron
does it make much difference
Posted 22 October 2014 - 08:05 PM
Posted 22 October 2014 - 08:07 PM
I have done and can't say I've noticed any increase in performance to be honest. It does seem to increase the banging and popping on the overrun which as immature as it is... sounds cool.
Posted 22 October 2014 - 08:08 PM
I do :)
I think its a little bit more pokey but not by much, cant say much for mpg i only get about 18mpg and the type of fuel isn't going to make a difference.
At the end of the day its like £1 extra, if anything it makes you feel posh ;)
Edited by willava182, 22 October 2014 - 08:10 PM.
Posted 22 October 2014 - 08:09 PM
And I agree it makes it sound better :)
Posted 22 October 2014 - 08:10 PM
if you use your mini daily 'normal' unleaded is fine, if you use the mini occasionally every 3 tanks use super unleaded, apart from the 'go faster !!' element it contains various additives which are beneficial to the longevity of your fuel lines pump and fuel tank
Posted 22 October 2014 - 08:11 PM
Everyone has their opinion on this subject. In a carb Mini, you'll notice probably no difference unless you advance the ignition to suit.
In an injection Mini, this is done automatically, so you would be more likely to notice the difference straight away.
I always use Shell V-Power anyway mainly due to the fact it is a better quality fuel, and it keeps the engine cleaner.
Do a search on the subject, this has been covered extensively multiple times.
Edited by HarrysMini, 22 October 2014 - 08:12 PM.
Posted 22 October 2014 - 08:12 PM
Unless you are running a higher compression ratio than standard it makes no difference. All the additional RON means is that with a higher compression a greater ignition advance can be run without detonation and more power/torque extracted without damage to pistons/piston rings.
To put 97+ petrol in a car with a standard dizzy and comp. ratio is just wasting money.
Posted 22 October 2014 - 08:16 PM
Posted 22 October 2014 - 09:25 PM
Edited by timmy850, 22 October 2014 - 09:26 PM.
Posted 22 October 2014 - 09:49 PM
Always Super Unleaded for me plus Millers VSPE Power Plus.
Not only for the added octane rating but for the shelf life of the fuel as well. Great for when the car is put to bed over the winter months! No gummed up carb or fuel lines, stale fuel and a car that won't start!
Posted 22 October 2014 - 10:05 PM
i noticed my mini seems to run a little cooler on super unleaded and stopped over run when turning the engine off after my drive home.
it's only £1.25 a litre for the super unleaded compared to £1.23 for normal at my local.
i seem to do slightly better mpg on super unleaded too, £10 a week is all i use as work is only 4 mile away.
Rhys
Posted 22 October 2014 - 11:19 PM
I do, mainly because my daily driver only runs on the high octane stuff. I know if i was chopping and changing, one tired morning, i would sendup filling my daily with the cheap fuel and ruin it. Not worth the risk and the mini now doesn't really like running on normal fuel anyway. better pops and bangs on over run too
Posted 23 October 2014 - 10:47 AM
they did a test when I was living in AUS
showed a 5% better fuel with v power
over normal fuel so realy pays for itself
its also a better fuel
Posted 23 October 2014 - 01:29 PM
+1, v power in both my Minis and diesel daily, really makes a difference.
Edited by Midas Mk1, 23 October 2014 - 01:29 PM.
