Just Needs A Passenger Door, Eh?
24 replies to this topic
#1 sharkojoints
sharkojoints
  • 11 posts
Posted 30 October 2014 - 06:09 PM
Surely the shell is twisted - look at the top of the windscreen?
More pics here:
http://www.ebay.co.u...=item3f3e7eeb67
No connection with the car or vendor - just curious whether this kind of damage was as minor as they seem to make out.
#2 mini stephen
mini stephen
  • 138 posts
  • Local Club: unkown
Posted 30 October 2014 - 06:21 PM
Hi minis to me are easy to fix as long as u have another one to measure off and have the skill (my father) lol main thing for me would not be the windscreen I would be measurein wheel to wheel to check for any difference if their is ur in a lot of work if not its easy pull measure cut weld always remember to keep measurein back wheel caught my eye before roof lol
#3 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 30 October 2014 - 06:23 PM
From the way the glass has cracked I think you're right, the shell has twisted. Looks like it might have been rolled onto its side to me
Edited by Harrison541, 30 October 2014 - 06:24 PM.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 30 October 2014 - 06:25 PM
the damage doesn't look to bad but in the pics it looks like the passengers a pillar is bent slightly, which could be why the screen is smashed. not worth that much though.
#5 Carlos W
Carlos W
  • 10,110 posts
Posted 30 October 2014 - 06:26 PM
I agree.
Would another windscreen fit?????
#6 Carlos W
Carlos W
  • 10,110 posts
£2400?
Are they out of their mind?
#7 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 30 October 2014 - 06:32 PM
The second picture for me is the one that makes it look twisted. Its certainly not just a new door that is for sure! Probably worth a few hundred maximum to anyone wanting to sell the interior and engine etc. Might be a good donor car though for anyone needing a lot of parts.
#8 Harrison541
Harrison541
  • 498 posts
Posted 30 October 2014 - 06:35 PM
The seam joining the roof to the windscreen frame has buckled
The windscreen has a suspicious crack (probably from it being twisted)
Rear wheel arch is missing
Door handle is snapped
Wing mirror is missing
Windscreen to door frame seam is bent
Side roof guttering is bent
Rear roof guttering may possible be bent
I think the car has been rolled, and should probably go to a scrapyard :unsure:
Edited by Harrison541, 30 October 2014 - 06:37 PM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 October 2014 - 06:48 PM
First thing I would be doing is running a hpi check on it..
It's be rolled over by the looks of it, rather than rolled, ie some piss heads have decided it'll be fun to pick it up and stick it  on it's side and push it down the road.
which would normally mean it's a cat C write off, if it's subject to an insurance claim... which would then mean either the owner has not put it through the insurance, or he's bought it back as salvage....
IMO it's over priced, not very well described and could actually be not the owners to sell....
#10 sledgehammer
sledgehammer
  • 3,060 posts
Posted 30 October 2014 - 07:02 PM
IMHO
window screen aperture deformed - so roof will need pulling back into shape - ie shell distorted
center of roof looks higher so may need window surround panel / scuttle
scuttle showing rust
more to worry about is that age may have a fair bit of rust hidden - that has been loosened by the distortion
much more than a door - could end up an expensive project
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 30 October 2014 - 07:16 PM
That would need a thorough inspection to see what's going on with the roof. Way overpriced.
#12 Black.Ghost
Black.Ghost
  • 2,567 posts
Posted 30 October 2014 - 09:11 PM
Assuming he isn't just displaying an old disc, the tax ran out last July - so the car was either sat for over a year before whatever happened happened, or it happened a long time ago and he is only just selling it now.
His best bet is strip and sell for parts. The MPis have a range of desirable parts so it should't be a problem making one money, but it will some way off what he is hoping for.
#13 CityEPete
CityEPete
  • 3,920 posts
Posted 30 October 2014 - 09:19 PM
To be fair it does need a door, so the advert is partly accurate, lol
#14 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 30 October 2014 - 09:32 PM
You could just make sure you park it everywhere with the offside facing out haha
#15 Mini-Mad-Craig
Posted 30 October 2014 - 09:56 PM
Considering this led to a comprehensive rebuild you can't trust the pictures. This shell was completely twisted with one wheel sticking out 2" too far on one side and 2" too far in on the other. Things could be bent that you can't tell in the picture. I'd want to do a full inspection of the floors and subframe mounting points etc before any more was said. That said theres £1500 worth of parts there. As said, it needs a HPI test.
anything can be saved :-)
