1980 Mini1275 Gt - Aka The Tart
clubman
290 replies to this topic
#256 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 20 February 2017 - 08:16 AM
As promised at last I've made a start on welding the front end.
First on was the front panel.
Plug welded.
Cleaned up and primed.
Next both A-panels.
Both cleaned up, the lip folded over and primered.
Ger
#257 ger
ger
  • Just Joined
  • 233 posts
Posted 27 February 2017 - 07:14 AM
Drivers wing welded on. Made a start in grinding gown the welds but not finished yet.
Ger
#258 ger
ger
  • Just Joined
  • 233 posts
Posted 06 March 2017 - 07:30 AM
Welds ground down and primered.
Passenger wing and two pipe clips are all thats left to weld on - I think.
Ger
#259 Rocket.
Rocket.
  • 1,441 posts
Posted 06 March 2017 - 11:48 AM
Lovely work! Looks spot on
#260 jamesquintin
jamesquintin
  • 1,017 posts
Posted 06 March 2017 - 11:52 AM
Don't forget the a-panel -> wing stiffener...
#261 ger
ger
  • Just Joined
  • 233 posts
Posted 06 March 2017 - 01:09 PM
Yer cheers for that. I almost forgot.
Ger
#262 ger
ger
  • Just Joined
  • 233 posts
Posted 20 March 2017 - 07:27 AM
A milestone was completed this w/e.
All The welding has been completed.  :proud:
Passenger wing on, welds ground down and primered.
Strengtheners made for the A-panel/wing joint, welded on ground down, and primered.
Back on the jig ready for seam sealing.
Ger
#263 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 20 March 2017 - 11:12 AM
Looking good! guess your glad all welding is now complete, marathon seam seal
job then on to paint
well done
#264 johnR
johnR
  • 2,244 posts
Posted 20 March 2017 - 11:56 AM
Looking good.
Wow a two fire extinguisher garage!! :-)
This is a man who appears to have membership of both the AA and the RAC (going by the badges in the first pic - he doesn't take chances! :D
#265 ger
ger
  • Just Joined
  • 233 posts
Posted 09 December 2018 - 02:41 PM
Apologies for the lack of updates, been a lot going on and a lot getting done. I'll break up the rather large update into smaller ones so that you're not over whelmed.
So here we go
All this takes place from March 2017 to present.
Seam sealing done.
Next was to send the engine away to have a refresh - or so i thought.
It went to Thomas Classic and Modern and when stripped down wasn't good.
So anyway that had to be sorted.
The following is the new engine/gearbox spec. Needless to say she's not a 1275GT any more but a 1380GT.
Engine Rebuild by Ross Thomas of Thomas Classic & Modern Dec 2017
Bored to 1380 cc
New Crankshaft
Calver ST unleaded big valve head with stainless steel MAR Motorsport valves
MAR Motorsport pistons
Duplex timing chain
MED lightened flywheel, pre verto clutch with orange diaphragm
AC Dodd RT fast road cam
Lucas 45D distributor, AC Dodd recurved with Luminition electronic ignition module
HIF44 carb, AC Dodd serviced and tuned for fast road
Xpin diff with 3.1 final drive
Blueprinted oil pump
Maniflow LCB Stage 2 manifold with Volcanic Black ceramic coating by Performance 1 coatings
Fletcher stainless steel side exit exhaust with stainless steel link pipe
2 Core aluminium radiator
I think that's all.
Underneath epoxy primed, coated with Raptor then at least 4 coats of black coach paint.
Epoxy primer.
Raptor.
Coachpaint.
Then off to the bodyshop for her paint.
I will continue and complete the update to where she is in the coming week.
Ger
Edited by ger, 09 December 2018 - 02:49 PM.
#266 ger
ger
  • Just Joined
  • 233 posts
Posted 10 December 2018 - 06:00 AM
As the shell was away at the bodyshop it was time to get all the other jobs done.
1st was to strip down the front subframe.
And buy a new rear subby.
Both were then sent for blasting and powdercoating.
And while they were away the front suspension arms, front and rear hubs and radius arms were stripped and painted.
Nice and painted.
All back together with new bearings/swivel pins.
And with cv joints, disks and driveshafts ready for front subframe rebuild.
Same goes for the rear subframe.
All ready to be put back together.
Ger
#267 ger
ger
  • Just Joined
  • 233 posts
Posted 10 December 2018 - 06:03 AM
More refurbing, this time the startermotor.
New brushes and a coat of paint
Made new extended seat brackets.
And had those powdercoated as well.
Also made a bracket for a brake bias valve that I will be fitting to the bulkhead cross member as I'm fitting a later servo unit to uprate the brakes as well as a bracket for a fuel filter/regulator.
Servo bracket and pedal box powdercoated and reassembled.
Servo stripped down and a service kit fitted (that was a bugger to get back together).
Here you can see the brackets and where the brake bias valve was situated (at the bottom of the servo to the left). I later moved the fuel filter to the other side of the bulkhead nearer the fuel pump as you can see from the next pic.
Now as the fuel filter was where the original washer bottle was I got one from an SPi and fitted it to the inner wing by the brake servo.
Next was an electrical repair of the indicator stalk. Nasty connectors from the previous owner were removed and new cable was used and soldered in.
All finished off with loom tape.
Ger
Edited by ger, 10 December 2018 - 06:05 AM.
#268 Vinay-RS
Vinay-RS
  • 2,093 posts
Posted 10 December 2018 - 06:20 AM
Lovely work on the subframes and fittings! They look great! I really like the seat extender brackets that you made and the bracket for the fuel filter. I'd love to make seat extender brackets like that.
#269 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 10 December 2018 - 10:25 AM
Awesome! Glad to see some updates!
#270 ger
ger
  • Just Joined
  • 233 posts
Posted 10 December 2018 - 01:16 PM
And as she was away getting painted there was a lovely empty garage so I thought I'd get the spray gun out and paint the wheels, tank and grille.
Finished wheels, by no means perfect. I'll see how they go and might get them powdercoated next year.
The finished grille.
Also went shopping and bought complete Fletcher stainless steel exhaust, alloy radiator, Maniflow LCB Stage 2 manifold and new front and rear wiring looms.
The picture doesn't do the tailpipe justice.
Looms.
I had the manifold ceramic coated in Volcanic black by Performance 1 coatings in Oxford.
Ger
Also tagged with one or more of these keywords: clubman
