Looking good ill follow this till the end... progress being what it is about a week on friday ;)
#46
Posted 07 January 2015 - 01:04 AM
#47
Posted 07 January 2015 - 12:24 PM
jim5770 - Hopefully the plan is to be ready for IMM 2017 in Ireland, so I've set a target to get the bodywork finished by this time next year then a leisurely?? rebuild so I'm not going to rush.
DEPS - This is my first resto so just had a good read of many the project threads on here to get some ideas. Saying that I think i may have gone OTT on the shell bracing - even added a bit more last w/e - bracing the toe board using the subby mount holes. To do any work inside the shell now is a bit like The Krypton Factor
See what I mean.......
I'm planning to take the toe board off on the w/e so there'll be a bit more bracing to hold the bottom of the bulkhead to stop it flapping about.
Ger
#48
Posted 07 January 2015 - 12:56 PM
Subscribed
#49
Posted 07 January 2015 - 01:11 PM
#50
Posted 11 January 2015 - 01:06 PM
your really going to town on this! nice to see you doing it properly! that box section on the bulk head is overlooked so often! great job
Edited by domdee, 11 January 2015 - 01:07 PM.
#51
Posted 12 January 2015 - 08:21 PM
Just a small update from last w/e.
Took the toeboard off, cut out a couple of rusty bits and made some plates.
Ger
#52
Posted 12 January 2015 - 08:30 PM
#53
Posted 02 February 2015 - 08:05 AM
Another Update........
Filled in some more small holes and cut out and plated bit more rot.
I had to redo the bottom right of the bulkhead as the metal was so thin I kept blowing holes and making a mess so I cut out even more and put a bigger patch in.
Then another run over with a wire brush and painted with zinc primer.
At the end of last week I put in orders to Minispares and MiniSpeed so hopefully more bits will be here for next w/e.
Any comments welcomed.
Ger
Edited by ger, 02 February 2015 - 08:13 AM.
#54
Posted 02 February 2015 - 07:16 PM
#55
Posted 03 February 2015 - 04:44 AM
#56
Posted 03 February 2015 - 10:17 AM
Looking good!
Some nice repairs going on there
#57
Posted 09 February 2015 - 07:29 AM
These arrived at the end of last week but not the bits that I wanted to do this w/e.
As the toeboard and front crossmember didn't turn up, so put the bonet hinge mounts back on and primed them.
Also decided to strip the rear subby while I was at it.
Hopefully a major step foward next w/e.
Ger
Edited by ger, 09 February 2015 - 07:30 AM.
#58
Posted 12 February 2015 - 01:31 PM
As you're a few steps ahead of me on a very similar journey I shall be following your project with much interest, great work so far!
#59
Posted 12 February 2015 - 01:40 PM
Nice little project you have there I do like the 1275 GT's so will be watching this one...
#60
Posted 12 February 2015 - 11:43 PM
looks very similar to some of the repairs I'm going to have to do soon so I'll be keeping an eye on this thread! Good luck with it all!
Also tagged with one or more of these keywords: clubman
Projects →
Mini Saloons →
Cape Town 🇿🇦 1275HleStarted by JAYO , 28 Feb 2021 clubman |
Projects →
Mini Saloons →
Budget Mini Clubman Shell Restoration For £1500Started by minimissions , 13 Nov 2019 clubman |
Projects →
Mini Saloons →
1275Gt Tarmac Rally Car - From ScratchStarted by KRM_Simon , 26 May 2019 clubman |
Projects →
Mini Saloons →
1275Gt Resto - From Flip To FactoryStarted by Verderad , 12 Mar 2018 clubman |
Projects →
Mini Saloons →
1977 Leyland Mini - 1275Started by parrellan , 27 Oct 2017 clubman |
