Update on the re-skinning, managed both doors now and started on the rear ones.
Made sure the inside was rust free and nice coat of paint on and weld through on the bits where I'll be welding, also made sure drainage holes at bottom, I did them in middle of the weld as weld is slightly raised so water can flow either side.
Clamped it down, tapped it round with hammer and dolly, also put a bolt through the handle screw hole to hold in place, but didn't do any welding till had chance to offer up, one door I used sealant around the inside edge before putting skin on apart from where welding, but this was little stressfull trying to make sure the door was in shape before welding it in the little time I had. I only welded a few places around the door lip, you can see a couple of V's I cut out that way could weld but grind down and not even tell there's weld there, but of course had to weld it up top where it fitted to window frame.
Time for new door hinge plates, 2.2mm thick stainless, that was hard on the drill bit!
The rear doors, cut off bottom skin section, not too bad inside after bit of cleaning up, just the lower part gone as per norm.
and the other side
Fitting this side isn't simple fold lip around, I managed to joggle the edge so easier to align and won't see when finished, I had to use a roller step joggler standard joggler wouldn't fit in.
Just got to repair the lower sections and then the skin should fit nicely(hopefully!).
